Question about Westinghouse Washing Machines
Westinghouse LT819S error code 3F - Westinghouse Washing Machines
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: I have a westinghouse washing
If water is not filling then it can be the failure of the inlet valve, if water fills but does not stop the error can be the water level sensor and if the motor does not work with voltage to the motor, it is failure of the motor.
However if there is no response at all then the control board is faulty.
Posted on Sep 13, 2010
What is q code 3f in asus motherboard?
memory is dead ,DDR on mine,
both my M5a from ASUS
I have post card (PCI p.o.s.t) too.
all other codes are , (drum roll) at ASUS
as seen here.
http://www.asusqcodes.com/index.php?inputCode='
some are missing, so ... ASUS docs are not 100% yet.
just pulled my ram now, post error 3F.
Nov 04, 2016 | Computers & Internet
Fault code 3F? Westinghouse smart drive LT819S
i found this answer in another place
The F3 is as follows,
F3= Motor Sensing Fault.
Either the motor is faulty, or the sensor attached to the middle of the motor is faulty.
You can check the windings on the motor for correct resistances at the wiring connections on the harness plug.
Pins 1/2 should be 32 OHMS,
Pins 2/3 should be 32 OHMS,
Pins 1/3 should be 42/44 OHMS,
Any other readings apart from that means the motor is stuffed.
To remove it, undo the motor wiring connecter, undo the 2 bolts (1 on either side) of the motor and lift the motor away from the base of the machine. Also, you may have to undo the motor sensor wiring connecter also*
If the readings check out, then you need to replace the motor sensor which is attached to the very middle of the motor, visible from underneath looking up at the motor.
Mar 09, 2015 | Westinghouse Washing Machines
Error code 2813 means what?
You can go to the KODAK Web site but it indicates they no longer support that system since 2012.
http://support.en.kodak.com/app/answers/detail/a_id/3569/~/how-do-i-resolve-easyshare-software-error-codes%3F/selected/true
Nov 03, 2014 | Kodak EasyShare Office Equipment &...
What does h22 mean on my Westinghouse dishwasher screen
Need more information; Model? Malfunction?
Error Code h22 Not found
Error Code 20 is failure to drain STOP, OFF and SHUTDOWN
http://kitchen.manualsonline.com/manuals/mfg/westinghouse/wsf6602.html?p=15
Jun 29, 2014 | Dishwashers
Westinghouse LT819S washing machine
I dont think its lube, if its direct drivce, the main issue with them is it puts strain on the motor when using a large load or even smaller ones over time. Get the motor checked and be careful because electronics catch fire very easily when you hear abnormal sounds, they burn or break, thats what happens to all electronics in the end even if in good care.
Aug 30, 2013 | Washing Machines
Westinghouse LT819S 1F error and beep.
hello there
This is a verry common issue with these ovens
Here is the meaning and a few things to determine what is at fault i have it listed below
this error code can actually show up as any 1 of these and they all mean the same thing
F0 -
F1 - F7 Stuck keypad
may mean relay is turned on.or has
failed
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 21, 2011 | Kitchen Ranges
I have a westinghouse washing machine LT819S with error code 3f any segestion how to fix
Sep 13, 2010 | Washing Machines
Washing Machines Logo
64 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
