Samsung ER-290 till roll jam
As my till roll was running out I fed through the remaining roll, but when I tried to insert the new roll the paper wouldn't feed through. I assume there is a tiny bit of paper left inbetween the feeder. I have tried turning the till on and off again, and everything appears to be turning, apart from the feeder on the till roll feed. Do you know a simple solution to clear the feed? Thank you
  • 624 Answers
SOURCE: Paper Jam at 2
Its probably not picking up paper from that tray, thus the jam error. For me that is typically because the tray isn?t pushing the paper up high enough to be caught by the pickup roller or the pickup rubber band is worn.
Posted on Feb 02, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Paper feed problem
Sound like something foreign is in paper path
Posted on Dec 24, 2007
  • 7 Answers
SOURCE: Fake paper jam
I am running Vista Ultimate SP1 x64 all updates and have been trying to sort out the fake paper jam on my Epson R300. I tried compressed air from my workshop compressor; believe me if anything was blocking the feed it wouldn't after I blasted it lol! anyway I also tried running some thick card through and still nothing, did some button pressing to get out of maintenance errors and all sorts of other things. I was about 5 mins away from reluctantly scrapping the printer when I happened across SSC Utility.
I downloaded SSC Utility, but there didn't seem to be much that would sort out the paper jam so out of curiosity I decided to click a few things and then test the printer.
The only thing I ended up Clicking was 'Reset Protection Counter' and that worked, it printed out fine.
so that was my solution, we'll see how long it lasts.
Posted on Oct 07, 2008
  • 13433 Answers
SOURCE: Cannot clear paper jam on L7580.
give this a try
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Aug 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
My samsung er 290 wont stop printing till roll
system option 21.Key on pgm press 21-RA-1-PO-CASH. Turn you key to reg and press PO. Good luck
Jan 28, 2014 | Sam4s Samsung Er-290 Cash Register
Till roll print says power fail. cannot open the cash draw.
The power has been turned of before the sale was finished. Make sure it has a new roll of paper in the printer, then turn key to PGM and switch the power off. Hold down the SUBT key while you turn on the power - display will say INITIAL or something similar. Turn key back to R and see if it works.
Dec 23, 2013 | Samsung SAM4s ER-650 Cash Register
How to change batterys in samsung er 290
you need to give it to qualified personell
Apr 12, 2013 | Sam4s Samsung Er-290 Cash Register
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Paper jam with multiple pages jammed
    in laser jet 1100 you need to open the front door and pull the paper form the front slot and if its stuck in fuser its need to open with the help of star screw driver and open the fussier cover to access the paper
    note be care full for the paper end sensor just below the fussier as its very delicate and may get broken with access force on it
    replace sapration pad for multi paper picking problem
    Aug 11, 2008 | Dell 1100 Laser Printer
    Panasonic Fax Phone Can't send or Receive fax
    there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
    hope this helps.
    wg
    Feb 10, 2008 | Office Equipment & Supplies
    56 people viewed this question
    k24674
    jasbo
    jasbo
