Question about Minolta Office Equipment & Supplies
Code C-004F MINOLTA DI 450
Posted on Mar 21, 2013
  • 1297 Answers
SOURCE: minolta copier di-450 code : c-143e
The correct error code is C 143E - EDH malfunctions.Please reset the malfunctuion code to open and closed the front door,or turn OFF wait 5 sec. and turn ON the power switch.If the problem persist change the image processing board.
Pick up motor malfunction
Whwn the document handling tray goes to up the pick up raised position sensor is not unblocked when the motor started turning forward.Whwn thw DHT goes down the pick up lower position sensor is not unblocked after the motors started turning backward.
During ascent motion check :
1.Foreign matter on pick up motor gear
2.Pick up motor operatio.The voltage across PJ11A 1 of main control board and GND is 0V when the motor is deenergized and 24 V when the motor is energized when the DHT is raised after the malfunction reset.
3.Pick up raised position sensor operation.
Change the motor,sensor or main control board.
During descent motion
1.Check the pick up motor gear.
2.Check the pick up motor operation
3Check the pick up lower position sensor operation.
Posted on Aug 28, 2009
  • 589 Answers
SOURCE: minolta di 251
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
Posted on Jan 11, 2008
  • 145 Answers
if it;s not the bottle home position it may be you toner happer motor...clean it and try to take the bottle our and close the door and than put bottle back in
hope that help
Posted on Feb 28, 2009
  • 10515 Answers
SOURCE: MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Posted on Mar 25, 2009
  • 6595 Answers
SOURCE: I have a trouble code (cobao) with a minolta di
Elevation drive motor failure. was there or Is there anything under the trays of the finisher (where the copies come out?) look over the exit trays make sure ther is no damage or binding. Open close finiher door turn power off then on.
Posted on Jul 19, 2009
Code 13 & 14
missing so"C-xxxx" or the wrong model number
Mar 04, 2014 | Konica Minolta Minolta DI-450 550 Toner...
Minolta Di 450 code 13 & 14
need additional numbers codes are c-xxxxx
Mar 03, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
The problem is the print head that is were the LASER is located open close the front door to reset if it comes back replace the print head
Feb 01, 2014 | Minolta DI-2010F Copier
The malfunction code is of c 33 minolta di 450
COF33 do you mean? Has the developer been replaced? the developer is located inside the drum unit. When this is done the counter for the developer needs to be reset and the F8 has to be run.
Feb 01, 2014 | Minolta Office Equipment & Supplies
Minolta di450 error code c0201
please sir, minolta copy di 450 ditected c 133b
Oct 22, 2011 | Konica Minolta DiALTA Di200 Copier
What is c0120 error
error code C-0120 in konika minolta model no C-450
Feb 03, 2011 | Konica Minolta Minolta DI1610P Printer,...
hope that help
Feb 25, 2009 | Konica Minolta DiALTA Di200 Copier
269 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
