Lightsheer et, error e3
Error code E3
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
Krazytech
  • 725 Answers
SOURCE: Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
Krazytech
  • 725 Answers
SOURCE: e3 code error.
rylee_smith
  • 8619 Answers
SOURCE: Error code E3
Hi
Thanks for using FixYa. Error E3 can occur due to one or more of these reasons--
3. A poor connection – Check wire harness connector to motor. Unplug connector and pull on each wire. If a wire connector comes loose from the plug, bend locking tab up as illustrated.
NOTE: If a locking tab is not properly seated in the plug connector, the terminals will not fully engage as the connector is plugged into the Motor Terminal Block. Inspect the terminals on the motor side of the connector. Straighten any bent terminals if they exist. Recheck the harness side of the terminal block if any bent terminals are found. Bent terminals can indicate a problem with the locking tab inside the plug.
Reconnect harness plug to Motor Terminal Block.
Run washer through a quick service cycle (wash and spin) to check motor operation.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 12, 2009
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Posted on Nov 22, 2009
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
The machine does not make copies showing an error E3 which i can not see where i can find it
yep!
e3 means a machine error and it need a service technician to fix it.
furthermore may i ask what e3 code displays on the screen (you might see something like this e3 10 , e3 40 , e3 01 etc)
i can still help you if it is e3 10
Jan 04, 2010 | Panasonic FP-7735 Black and White Copier
Getting code E3. What does this mean?
error E3 means Paper jam ..try to clean any paper inside...
May 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Aug 26, 2008 | Pitney Bowes C180 Copier
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
