Question about Samsung RS2534 Side by Side Refrigerator
Removng the drip tray from A Maytag
Maytag MFD2561HEW is there an easy way to remove the plastic drip tray? or do I need to remove the fan and compressor? something got in the tray (all slimed up) and smells like a dead cat down there! will Vinegar help? Or anything else since I soppped up all I could reach but there is still alot in there.
2 Suggested Answers
goodwinpeg
  • 744 Answers
SOURCE: I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Posted on Jan 20, 2015
Testimonial: "Thank you for your help. It would be nice if LG and Samsung put the drip trays in the front of the fridge. Thanks again."
How do i open the top to clean under the burners
Normally it's easy. Just lift the range top from the front andtheir should be a lever to pop up and support the range top while you clean. :)
Dec 02, 2015 | Maytag Kitchen Ranges
Maytag fridge works but freezer doesn't
Try the control relay/ condenser thats attached to the compressor and provides a momentary spike to start the compressor start windings prior to the unit going into run mode. reasonable and easy to fix
Apr 04, 2014 | Maytag Refrigerators
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
Feb 21, 2012 | Refrigerators
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
New Royal Professional Machine has the workd Dregraw.miss can not use the machine what must I do to get started need help.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Jan 10, 2011 | Saeco Royal Digital Plus Coffee...
Freezer icing up
Experienced this problem with Evaporator coil icing up (coil is located inside back wall of the freezer compartment; the ice/frost was visibly blocking the series of louvers or slots along the bottom of the freezer back wall. I think the power outage caused partial melting of an already somewhat iced coil, but when the power was restored the water on the coil just froze solid. When these slots become obstructed the Refrigerator will not cool to its proper 36-40 deg.F temperature and the compressor motor runs frequently and the noise level is louder than usual. SOLUTION: fastest and safest way to Defrost this iced up coil is: (1) turn off 120V power / unplug refrigerator from the outlet; (2) remove all food to another refrigerator / freezer and take out ice cube tray & flip icemaker bail wire to its up (off) position - but leave top freezer basket in-place; (3) remove Bottom freezer basket (which should lift up and out; (4) move refrigerator away from wall - and carefully unscrew and remove white-painted, rectangular metal panel at bottom in the back....... you will see a white plastic water tray below a small fan with black plastic blades...... have a 3x5 cellulose sponge and bucket handy...... (5) open freezer door all the way and set a 21-inch box fan on the floor in the opening or area where the Bottom freezer basket was removed... put a single towel on floor under the box fan if there is significant frost on the bottom of the freezer compartment (there should not normally be any); (5) turn the fan to "Medium" speed with air flow pointing toward the freezer... you will be amazed at how much faster this works than pans of hot water or hair dryers (the latter is potentially damaging and dangerous); (6) with a flashlight you should soon see the water drip-drip-dripping from a spot at the center and bottom of the Evaporator coil - where it goes down a white tube and into the white plastic pan beneath the small fan you saw in Step #4; after awhile (maybe 20 minutes) check the white plastic tray in the back - which will be full of water (sponge it out)... continue defrosting with the 21-inch box fan... check the plastic tray again - and sponge out the excess water. A completely iced-up coil will probably fill the plastic tray three times. Eventually the water will stop dripping - which means the Evaporator coil is completely defrosted. There may be some water that gets onto the floor under the left side of the refrigerator which you will have to wipe up. Reattach the metal panel and reinstall the Bottom freezer basket and ice tray. This process takes long enough that you can clean the inside of the refrigerator while you're at it.
Jul 09, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Maytag Neptune MAH6700AWW overflows out the detergent tray opening while filling
water leaks out of the plastic box where you put the detergent/bleach/fabric softener, from the OUTSIDE of the box onto tub, drips down tub on to metal tray and into drawer. Anyone had this problem?
Nov 07, 2009 | Maytag Washing Machines
GE SIDE BY SIDE/MODEL #GSS25JMDCC
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Feb 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag refrigerator model #MFD2561HEW, 2 years old, suddenly stopped cooling. Digital read out in fridge is currently reading 65 degrees
There is a fan in the back of the freezer(my was made in Korea) that blows air up to the fridge. I had a service tech replace mine but I would do it myself if it happened again. Its not hard to get to and is easy to replace.
Apr 06, 2008 | Refrigerators
Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
Mar 10, 2008 | Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
96 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
