Need a wiring diagram for simpson 22s650 washing machine
Need a simpson 22s650 wiring diagram
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: Simpson esprit650 Washing Machine. Main
Hello & Welcome to FixYa
Please click here if you want to buy this part. Please get back to me if you have any other questions.
Kevin
Posted on Mar 08, 2011
Wires on motherboard, which way around do the blue and brown wires go to the water level switch? Simpson 22s750 washing machine
There are more than one model of the 22s750, you need to give the full model number. All of the 22s750 models I have seen have wires on plugs. The plug goes in to the water level switch and the other end has a plug that goes on to the circuit board. Do you have seperate wires or have you pulled them out of the plug. Give the full details if you want help.
Oct 12, 2017 | Simpson Washing Machines
Excessive bowl swing on spin cycle - machine cuts-out. SIMPSON 22s650. tried adjust load balance but still wobbles to cut-out. Sometimes OK with an under loaded light load.
Sounds like it needs new suspension rods. One on each corner. The spring on the rod gets weak causing excessive bouncing & swinging.
Jul 17, 2017 | Simpson Washing Machines
Simpson washing machine ezi650 still wont drain after installing new pump
Why did you change the pump? Had you tested the old pump & made sure it was faulty? You need a multimeter and test the pump, the wiring for breaks and then check that power is actually getting to the pump. No power - No go!! If no power then probably a fualt on control board.
Jun 13, 2016 | Simpson Washing Machines
Hi All, I have Simpson Toploader SWT704 7.5kg washer. Its a 5 years old machine and recently it started thumping noise like an earthquake at the end of the washing cycle.
Try utube there is some videos there of similar machine designs that are very helpful or you can download a repair manual for your model through Simpson/Electrolux....hope this helps gl
Mar 15, 2016 | Simpson Washing Machines
Hi Allan, I have a Simpson enduro 801 washing 8KG Model No: 22S801 and I need a wiring diagram for this timer. If you can help me I would be very grateful, Allan.
Why do you need a wiring diagram? These things are permanently made part of the harness to the various parts. If you suspect the timer why not try another. There is little you could do to it, its likely to be a sealed unit. Tell us more about the fault?
Jul 21, 2014 | Washing Machines
I have a Simpson Ezi Set 450 top loader washing machine which doing everything else although it will not agitate, why?
Fairly common issue. Motor control module is shot.
You can get them from your local parts shop, or ebay.
Sometimes they are direct swap by the big plug, sometimes there is slight rewiring required (wiring diagram comes in kit and they are just spade connectors on to the timer, no splicing or anything).
If you take the top panel off and it does not have a module exactly like in the pic on ebay, make sure you are happy to do the wiring bit before buying (easy if you can read a simple wiring diagram)
http://www.ebay.com.au/itm/0628271101-NEW-Simpson-Hoover-Reversing-Motor-Control-Module-GENUINE-/201054721557?pt=AU_ApplianceAccessoriesParts&hash=item2ecfcb9615&_uhb=1
May 26, 2014 | Simpson Washing Machines
Simpson washing machine 950 no motor
Hi just read your post.Had this problem before.Now are there 3 wires in a terminal block that go to the motor? could be one of them is broken.I have found that because the wires are so thin they break alot.Check all the wires for breaks from the drain pump to the motor.Could be a broken nuetral.Make sure you use a bright torch and make sure the machine is unplugged at the power point before looking.Please reply back to let me know how you got on.Looking forward to your reply.Regards LU
Jan 26, 2014 | Simpson Washing Machines
I need a schematic diagram for simpson riveria22p728-e washing machine
My oil light staying on and not getting oil to the valves. Is it my oil pump or where should I start?
Jan 04, 2013 | Simpson Washing Machines
Need manual please for Simpson Esprit Frontloader washing machine 6.5kg
You can find the manual here >
http://www.simpson.com.au/content/brand/brochure
Copy and paste this URL into your web browser..
Aug 08, 2011 | Washing Machines
INSTUCTION MANUAL REQUIRED
This online company list all Indesit WM manual:
http://www.unbeatable.co.uk/manuals/Indesit-Washing-Machines/27916330.html
From them:
Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
no_image_large.jpg Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
May 26, 2009 | Indesit Washing Machines
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
