Question about Epson Office Equipment & Supplies
Epson tm-t20 printing slow
Slow printing with serial interface
5 Suggested Answers
Nitrotrike
  • 589 Answers
SOURCE: Epson TM-T88#P thermal printer driver for windoze vista
You can use windows 2000 drivers on Vista for this printer, according to this article:
http://www.prophetline.com/node/141
Posted on Jan 14, 2008
SOURCE: can't install epson tm-t88iii serial
unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Posted on Sep 02, 2008
SOURCE: tm-u295 firmware problem?
I can solve that problem but i need some help in the firmware of TM U220B. I just need the .bin files to downgrade to version 1.02
Posted on Feb 26, 2009
SOURCE: Hi, I have a problem with my EPSON TM U220PB..
Reinstall the driver and check. If it does not work, replace the cables and check.
Posted on Nov 12, 2009
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Epson TM 88II not working with Win XP SP2
Are you confident this is using a parallel interface?
The ones I used to work with used a 25pin to 9pin serial connection. The 25 pin connection on the printer is the same as a parrallel port on a PC, but if you think of a normal parallel lead the printer should use a 'centronics' connector to conform to this. I think you may need a 25pin to 9pin serial lead which aren't very common but plenty of people should still make them.
Stephen
Feb 18, 2010 | Epson TM T88II Label Printer
Epson TM-U220PD printer network card problem - recognition
Did you change the dip switches? I believe that for the serial printer to work with ethernet, you need to have switches 2 and 4 on bank 2 set to on.
Jul 13, 2009 | Epson TM-U220 Matrix Printer
Tm-u295 firmware problem?
Feb 18, 2009 | Epson TM-U295 Matrix Printer
TMu220 serie 25 for usb
Hi
option 1 - buy a pci parallel card
option2 - buy a cable serial 25 to usb the cost is $30 dlls
Oct 26, 2008 | Epson TM-U220 Matrix Printer
Can't install epson tm-t88iii serial
reboot your system.
it works to me.
Aug 19, 2008 | Epson TM-T88III Thermal Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
??????????? printer doesn't stop printing, help!
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
Jul 01, 2007 | Epson TM-L90
426 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
