Question about ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ)
A7N8X-E Deluxe Nforce2 will not POST
Removed the board and processor from one computer and installed in new case with hard drives from another XPSP2 machine. Powers up all components but no splash screen and will not POST. No beeps, no nothing. Power on diode lights up, fans and HD spin, but that's it. Any help appreciated.
  • 3 more comments
  • carlsback40 Jan 04, 2009
    Am doing this now, but memory should not be the problem. This board, its processor and all memory came out of another machine and was working just fine. Sat for about two months in a new Antec case and I've just added HDs, optical drives and the video card that was in it before. Not compatibility issues as far as I can see, b/c all board components were working with this board before. I'll do as you suggest.
    I understand what you've said, but I think it may be more complicated. Since my last post I rebuilt the system again. There is no video whatsoever. Shouldn't I see the Asus splash screen at least? If XP needs to be reinstalled, what's the correct way to do it assuming a 2 HD 2 optical drive system? How do I get the machine to boot from the optical drive if I can't get into the bios setting?
    gnomer (linux?),
    I tore it down and redid everything with the bare essentials as you suggested. This was the second time I did so, but another change was crucial. This time I got the splash and cmos set up because: (1) I put in a very low grade pci express video card that did not need a lot of special drivers, etc. which in turn lit the monitor; and (2) I turned off the monitor and then booted first. I'm sure you're right and that I'll still need to reinstall xp. So now I'm cloning the HD on this computer using my external drive and Acronis. I'm going to boot to the xp cd and see what happens after that. Now that it's posting I know the processor, board and memory are OK based on what I saw in the set up screens. I was in too much of a hurry and should have known that trying to install the video card would be asking for trouble even without the xp issue. Somtimes you just gotta slow down and think. Isn't that a shame?
  • carlsback40 Jan 09, 2009
    BTW, my philosophy on bios after a disaster with MSI automatic upgrade was that I never touch it unless there is absolutely no other solution available. In the MSI bios updated itself then the everything got buggy. I then found a permanent post on their page saying-DON'T USE THE AUTOMATIC BIOS UPGRADE WE SENT INCLUDED WITH YOUR BOARD, TURN BACK, TURN BACK!!!!!!!!!!!!!!! Of course, by then you know what happened. Fortunately Newegg was very cool about it.
  • Dick
    Dick May 11, 2010
    Reseat memory and video card, try again.
  • 28 Answers
I had the same issue a while back. You need to reinstall windows on the new PC. Your motherboard is expecting to see a certain hard drive that has the windows boot sector on it. If it doesn't see that exact hard drive the computer will never boot... so quick fix, just reinstall windows and everything should work fine.
~gnomer
Posted on Jan 04, 2009
  • 1 more comment
  • Chris Dawson Jan 04, 2009
    You should take everything out but the bare necessities. meaning Motherboard, CD drive, power supply, and Hard Drive. see what happens. if you still don't get the Asus splash screen, make sure all the power cables are seated properly and everything is connected, if you still cant get to the bios settings, flash the bios, then you should be able to the asus splash and access the bios, set the boot device priority to the only Hard drive installed, install windows, then go back and plug everything else in. windows is plug and play so adding in everything else should make a difference.
    Hope that helps. If that still doesnt work, post back, and ill see what else i can think of to do.
    ~gnomer
    Im glad you were able to get to the flash screen and everything booted into bios properly. I am sorry I linked the wrong page from asus' website. If anything else goes wrong just comment back and I will see what I can do.
    I'm glad I could help,
    Gnomer
  • Chris Dawson Jan 09, 2009
    I'm glad Newegg, was understanding, they usually are. I'm glad everything worked out and you now have a working computer. Congrats.
    ~gnomer
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) When I built my PC in '05 I installed 4 HDD's on the A7N8X-E Deluxe. Now my main drive is failing so I've cloned it to a new HDD, but...
hi Memory,
You can try 2 things:
1. If the HDD has jumpers make sure to set the one you want to boot from as the master.
2. Go into your BIOS and choose which device to boot from first.
Also just to be sure disable all other drives and boot with the single drive to ensure that it actually works. There are bootdisks that can help with booting issues one being called ultimate boot cd but i wouldn't touch settings unless you know what your doing.
Hope this helps,
Omeil
Jan 31, 2011 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Hi, cannot find the right set of drivers for the mobo A7N8X Deluxe. It does not recognise my SATA drive, even I've installed corresponding drivers After pressing the F6 key and installing the SCSI Drivers...
Connect your SATA on the first SATA slot to make it as the Master. Or maybe the BIOS settings is set only to recognize IDE device. If this is the case, try going to BIOS settings then Peripheral Devices, look for the menu Hard Drive and replace the IDE into SATA.
Feb 04, 2010 | ASUS A7N8X Motherboard
Computer boot problem
Temporarily swapping-in another power-supply is the first thing to try.
Don't connect the disk-drives, CD/DVD drive, nor 3.5-inch drive.
If the computer "beeps", and shows the POST (Power On Self Test) screen, then changing the power-supply is the solution.
Look at the motherboard -- any "blown" or "bulging" capacitors?
Oct 27, 2009 | ASUS A7N8X-E Deluxe Motherboard
No Post No Beeps just lights and fans
If the computer just turns lights and fans thats because you have a piece of hardware that is unable to start.
My guess is that you burnt one of the three:
The CPU
The Board
A Card attached.
Disconnect the hard disks and DVD CD drives
Try removing a ram slot at a time and keep trying, keep doing that for all the pieces until you have none.
If at the end (when you get to a part where you only have Board and VGA plugged the computer still doesn't boot up, the best sollution is to try these 3 on another pc to make sure they are faulty before sending them to vendor.
Good luck
Jun 20, 2009 | ASUS K8VSE Deluxe (K8VSE-DELUXE 10PAK)...
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
W3507motherboard front panel connections
The manual is Here:
http://dlcdnet.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x-e/e1876_a7n8x-e_deluxe.pdf
However, wires to the case are specified by the case maker (you did not specify). Just about all of them mark the connectors on the wire ends with their functions. Just match with the manual's jumper description.
Apr 17, 2009 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
ASUS M2N32 SLI Deluxe - Fans Come On But Board Doesn't Post
there should be a four pin connector from the psu to the mobo,if thats not it try removing memory sticks one at a time, just make sure you leave one in
Apr 09, 2009 | ASUS AI Lifestylestyle M2N32-SLI...
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
Pc upgrade !
IAN.S
Where you need to be is on Asus web site. Your board can handle ONLY; Athlon XP 3200+(400 MHz FSB)(Model 10)(Barton), AXDA3200BOX
With that CPU you must also have bios version 1004.
Check PCB and BIOS versions before flashing BIOS!
asus A7N8X supported CPU click here; http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7N8X
Since you seem to need your manual. Click the link:
http://dlsvr01.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x/e1859_a7n8x.pdf
You do not have an intergrated video card. You have a 1.5v 8x
AGP video slot.
I suggest you call Asus & make sure your CPU model AXDA3200DKV4E will be supported over model AXDA3200BOX.
You can call Asus tech M-F EST at 812-282-2787.
Good luck & Have a great day!
Mar 16, 2008 | ASUS A7V8X Motherboard
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) Logo
168 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
