Question about John Deere Garden
I cant seem to get the shift knob replacement for my scotts s1742 tractor
3 Suggested Answers
  • 25 Answers
SOURCE: briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Posted on Jun 23, 2009
ftw1952
  • 10319 Answers
SOURCE: i need a wireing diagram
Your mower is manufacturered by John Deere if you did not know so the schematic will be the same. Thet are sold only through John Deere franchises. None are available on the web as far as I know. I have been looking for years of many models to complete my collection.
Also here is an owners manual in case you need it too
http://www.deere.com/en_US/homeowners/media/pdfs/products_non_current/scotts/lawn_tractors.pdf
Posted on Jul 16, 2011
My Scott's gx1642s riding mower hydro transmission
stuck check vavle replace 100.00 dollars at mower shop have to take in to fix if less than 1 year should be under warranty
Sep 14, 2014 | Garden
How to adjust tension on drive belt for scotts s1742 mower 42 "
Not sure it has an adjustment check for worn parts or belt.
Oct 05, 2013 | John Deere Garden
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
Craftsman rider mower 917259567 has a knob for adjusting the mowing height. how does it work, mine seems to be broken
The adjusment knob works only when the mower deck is in the UP, position. You then start by turning the knob CLOCKWISE, if you turn it far enough the mower deck wont go down. You back it off ( COUNTER-CLOCKWISE) to hold the deck in a lower position. Just rember you cant fine tune the heightsetting knob with the weight of the deck resting on the stop (knob), just pick the dech up a little then adjust the knob.
Hope this helps, Matt
Dec 11, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Just bought 1990 big bear and I cant seem to get it in reverse. What is the sequence?
down shift it into neutral then turn the reverse knob. while holding the reverse knob(still turned) down shift again and it should shift into rev. then just up shift to take it out of reverse
Oct 13, 2009 | 2003 Yamaha WR 450 F
Briggs and statton carb pouring fuel out
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
The transmission makes a grinding noise on my 2546 scotts mower
Does this noise happen while trying to shift it or while running it ?
Apr 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Remove the shift knob in a 1999 dodge dakota
The shift knob on a manual trans should twist off. Sometimes it takes a bunch of force. Are you replacing the knob? Then channel locks will work fine.
Mar 05, 2009 | 2001 Dodge Dakota
Transmission
its the lock-up solenoid that cause the problem driver side trany cover on top cant mist it . good luck pierre
Jun 24, 2008 | 1995 Oldsmobile Cutlass Ciera
Garden Logo
51 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
