Only my stanby on but once I press on it dimp but no picture or display.Please advice.Model LG PT-53A82 rear screen projection
Have u rectified the problem?
Posted on Aug 27, 2013
2 Suggested Answers
mistersony
  • 320 Answers
SOURCE: sony kdf50E2010 Rear projection model Tv
3 flashes indicates that the lamp is not seated properly or that the lamp door is not closed properly. Try removing and plugging tne lamp back in, tightening down the holding screws and reclosing and tightening the lamp cover. This should take care of your problem, Please be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
PT-53TW53 53 in. Rear Projection has sound but no picture
It is. And I hope you some cash set aside for this extremely costly repair.
I once had a rear projection TV and was told by the repairman that each of the 3 flourescent lamps run about $200.00 to replace.
Needless to say I did not get it fixed
Oct 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Double Display on screen
The convergence Ics need replacement along with the 2.2 ohm 2 watt resistors. There is a repair kit available for your model which contains both the ICs and all six of the resistors and contains step by step instructions with pictures. Heres the link to the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Mar 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
How to reset lamp timer
While pressing the VOL- button on the projection display,
hold down the PIP button on the remote control
simultaneously for more than 5 seconds. You will see a screen pop up that says "Lamp time was reset to 0" and the lamp indicator light will go out.
Dec 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic Rear Projection
You are on the right track. The problem is actually with the green convergence IC that controls the alignment. The convergence ic's take the information from the 3 pictures and align them into one picture on the back of your screen. Although this is an economical repair it is complicated and should be left to a quailfied service technician. If you are not sure of a local technician, panasonic's website has a servicer locator that can guide you to one. Hope this helps
Mar 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Projection off the screen?
Try pressing the "Aspect/Prog -" button on the remote - it should be just underneath the number 9 key - try pressing once, see if it fits better, try pressing again to see if it improves until you get a better match
Feb 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
