Question about Konica Minolta Office Equipment & Supplies
Error CD201 of konica minolta bizhuh c450 - Konica Minolta Office Equipment & Supplies
  • 60 Answers
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
Posted on May 27, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Konica Minolta Bizhub C450
You need to place service call for the transfer belt.
As for Sally's question, select the "seperate Scan" button to combine multiple documents as one file. This will work with or without the auto document feeder.
Posted on Jun 12, 2008
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Posted on Jul 18, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: KONICA MINOLTA C450 VXL Printer
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Posted on Dec 08, 2009
Error p5 in konica minolta c450
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed..
Mar 01, 2014 | Konica Minolta Office Equipment & Supplies
Error p 5 konica milnolta bizhub c450
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
P 5 error in konica milolta c450
Sir/Mam
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed.. recommended a tech do this unless you known what you are doing.
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Minolta C450 fault code C-2656
konica minolta bizhub c450 error code c2656
Feb 09, 2013 | Konica Minolta Office Equipment & Supplies
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
I have an error code C-D201 after removing fax option
CD201 = File Memory Mounting Error. On most Minolta's there is also a memory chip that goes with the fax option. Most likely this error is from you removing only part of the fax option. There is still a memory / dimm chip still installed that should not be.
Nov 30, 2009 | Konica Minolta bizhub C250 All-In-One...
219 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
