Question about IBM TravelStar Audio Players & Recorders
Is there a replacement battery for a philips 120 hdd jukebox
After a good number of years use the battery of my Philips hdd 120 seems to have thrown it in. Has anyone replaced the battery in one of these machines? Cheers
SOURCE: philips hdd120
Hi there Well i tried this and it worked Install net framework 2 (from microsoft) Also if you don't want to use the rubbish softward provided Download a programme called HERBERT Select your HDD 120 hard drive from my computer and install HERBERT on there - creat a shorcut of HERBERT to your desktop & you can put albums etc from that (you do have to ensure you have the latest firmware installed - Herbert can do this for you as well Then you should be ready to go - its a lot faster than DMM!!
Posted on Nov 30, 2006
SOURCE: I need serial # for a Philips Gogear SA177/00
sf000532001532 it's mine but i cannot charge it anymore. so i think you can use it!
Posted on Nov 05, 2007
  • 476 Answers
SOURCE: philips hdd 1630
The battery in the HDD1630 can be changed, but it's a bit fiddly to do.
Remove the hex screw from the back of the casing.
Gently lever the back cover off by insert a small flat blade or metal strip in between the front and back cover at the top. (Do not try to pull it off from the bottom.)
Tape along the buttons and switches down both sides of the player, so they don't fall out when you remove the front cover.
Undo the four cross head screws in the corners of the inner panel.
Gently ease the inner workings away from the front casing. Note the ribbon cable to the front panel.
Ease the buttons on both sides away from the inner casing. They are only stuck down with double sided tape.
Lift the metal plate away from the battery and hard disc, taking care not to pull the microphone out of the plastic end cap. (If it is pulled out, it can be stuck back in place on re-assembly.
Carefully lift the battery away from the board from the end opposite the wire. Pull the battery connector out of the socket and replace.
Re-assembly is the reverse procedure.
Posted on Feb 16, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: new battery?
Yes. It takes a Rechargeable Li-polymer 280mAh
battery. Just unscrew the back carefully with a miniature Phillips-head screwdriver and replace.
Posted on Mar 07, 2009
SmartAviator
  • 449 Answers
SOURCE: my philips gogear freezes every time i plug it in to my computer
Try keeping switch it ON position.
Posted on Jul 17, 2009
My daughter bought me a Philips handset telephone last year unfortunately I have lost the user manual that came with the phone, can to tell me how I can get a new one to set up my phone, thanks
If I were you I would just download the manual from Philips for nothing. I cannot give you a direct link because you do not specify the model number but you should be able to find it yourself easily. All Philips handset manuals are located on the relevant products pages which you should be able to find from navigating from the following link http://www.philips.co.uk/c-m-pc/phones
Jan 09, 2015 | Philips Lands Phones
Tip
Sony DLP Lamp XL-2400 How-To Replacement Guide. For Part Number: Sony Lamp...
For Part Number: Sony Lamp XL-2400 ( Sealed replacement lamp for televisions, SMALL & SEALED ).
Compatible Part Numbers: XL-2400, XL2400, XL-2400U, XL2400U, XL-2400E, XL2400E, F93087500, F-930-8750-0, A1129776A, A-112-9776-A
For Enclosure: Sony Lamp ( XL-2400 / 2-590-738 ).
Television Type: 3LCD.
For Bulb: UHP 120 / 100w 1.0 E 19.8
Philips UHP 120 / 100w 1.0
E 19.8 1.0 Philips.
on Mar 25, 2010 | Televison & Video
Format
  1. If you have not already installed the Device Manager, download the .exe file to install the latest version of the Device Manager application from http://www.philips.com/support. Enter your language preference and the model number e.g.hdd070. Select Software under Product Support on the left of the screen. Scroll down and click on the .exe file of your preferred language under the category PC software. The program will install both Musicmatch® Jukebox and Device Manager in one go automatically.
  2. Connect the hdd to the power supply with the AC/DC adapter.
  3. Launch the Device Manager at Start->Programs->Philips GoGear HDD->Philips GoGear HDD on your PC
    IMPORTANT: All music & content of your micro jukebox will be erased once the factory setting is restored.
  4. A dialogue box will pop up; click Restore and OK to confirm and start restoring the unit to its factory setting.
  5. Follow all screen instructions to complete the restoration.
  6. The Device Manager will close automatically once the success message is displayed. Safely remove your GoGear micro jukebox by clicking on the EJECT HARDWARE icon in your task tray bar. When prompted, "The USB Mass Storage Device can now be safely removed from the system", click OK and unplug your micro jukebox.
Mar 18, 2011 | Philips GoGear HDD075/17 MP3 Player
Toshiba hdd2171 has failed (no boot, very bad sounds coming from hard drive) any ideas what I can replace it with? Appears to be 2.5 inch, IDE 40gb, can i replace it with another toshiba ide hard drive,...
Yes, you can replace it with another Toshiba hdd 80GB or 120 GB. It doesn't have to be a Toshiba HDD. It can be any HDD that has an IDE interface for the ribbon cable to plug into. I prefer Western Digital hard drives myself, but Toshiba does make very good hard drives as well. There are several name brand HDDs out there. Just make sure you go with a name that you trust, I don't suggest going with some off-the-wall brand for a HDD. I've tried some "No Name" HDDs before and they have all failed within a 1-2 year period. You don't want to take the risk of an HDD crash and losing your data again within the next year.
Apr 12, 2010 | Toshiba (HDD2171) 40 GB Hard Drive
Device not recognized
Product selector site for the HDD120:
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&searchtxt=HDD120
For support on the matching model:
1. Enter your country in the top right.
2. Enter the exact Model Number on the left.
When more devices show up, select your model from the list.
Use next information and guide to get the player connected:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=US&subrequest=1&mid=Link_FAQs&new_tmpl=1&session=20091204185048_94.214.10.98&desc=Philips+Jukebox+HDD120+20GB*&view=aa12_view_full.html&list=aa12_list_partial.html&slg=ENG&refnr=0021019&refdisplay=PI_C48_PHOENIX_ARIZONA_023&dct=QAC&ctn=HDD120/17
Download link for the GoGear device detection:
http://www.p4c.philips.com/cgi-bin/dcbint/get?url=/sca/sca/060214/060214143352_10792.zip&ofn="Detect Philips GoGear Device_v3.zip"
Need more help ? Just post a comment.
Dec 04, 2009 | Philips HDD120 MP3 Player
Non Disk error... Compaq HP NC6400 3 Gb ram 120 Gb S ata hdd toshiba 1.83 Ghz Intel Core _____________________ well everything happened as the lamp above our table in the living room fell on my laptop...
Check the boot sequence in BIOS and make sure that you no usb device connected to your computer and also try to change you Sata mode in BIOS and see if that works.
Jul 27, 2009 | HP Computers & Internet
Our TV just started showing a blurred/double image which seems to be consistetly red/orange in color
Replace convergence Amps STK392-120.
# NOTE - If this info was helpful to anyone please click on yes!
Jun 19, 2009 | Philips 60PP9202 60" Rear Projection...
How to save music files in my philips jukebox?
you need cable interface to connect from your mp3 jukebox to a computer. your connection interface is thru USB (mini USB to USB cable). plug it in and your computer will automatically detect that new device. follow the on screen, open that device folder and download the music you wanted from your computer local drive to your philips jukebox. then you can download music (such as mp3 format) from your pc to mp3 philips jukebox. let us know.
Apr 16, 2009 | Philips GoGear HDD060 MP3 Player
120 g iPod completely dead
I would get the battery replaced. Unless you have dropped it or thrown it it is just the battery.
Mar 17, 2009 | Apple iPod classic MP3 Player
Dell GX270 does not recognise HDD after CMOS battery failure
It Seems to me IDE HDD In your BIOS should be set to on.
Mar 11, 2009 | Dell OptiPlex GX270 PC Desktop
60 people viewed this question
Top IBM Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an IBM Audio Player and Recorder Expert? Answer questions, earn points and help others
