Question about HP Computers & Internet
Motherboard manual hp dc7700
I need a motherboard manual fo a hp dc7700 motherboard. I have the motherboard but don't know the pins to set up front switches such power on,hard drive light,etc. can you help
SOURCE: Soltek SL-75KAV Motherboard
http://www.motherboards.org/mobot/manuals/Soltek/
Posted on Aug 31, 2007
  • 95 Answers
SOURCE: SL-75KAV
Here ya go http://www.motherboards.org/files/manuals/118/75kav.pdf
This has all the pictures you will need to reconnect everything. If this helps be sure to rate my help.
Posted on Jan 23, 2008
kigwa2008
  • 68 Answers
SOURCE: PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Posted on Jul 25, 2008
SOURCE: Acer Motherboard MS6772
This board uses typical INTEL styled pin header for front panel connections and is used on many major OEM boards. Here is the pin assignment:
Pin 1-3 HD LED (Red color in this particular board)
Pin 2-4 Power LED (Green)
Pin 5-7 RESET
Pin 6-8 Power ON/OFF
Note: Pin 10 is empty
Posted on Sep 13, 2008
SOURCE: Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Posted on Dec 05, 2008
Audio wiring problem on HP Compaq DC7100 CMT with DC7700 motherboard
You have a problem with HP connectivity. When I moved my dx7100 motherbard into another casing I experienced that error and also chassis fan not detected error. Chassis fan error is easy to remove, You only need a fan with at least 3 cables (with sensor) and plug it into 4 pin chassis fan connector. Audio conector have 10 pins (eight pin missing for orientation (with followed numerication
2 4 6 10
1 3 5 7 9
If you only want to get rid of the error ( with no use of back audio(use of another soundcard)) then short pins 2 and 7. But if you want to use back connectors, then you must bridge with jumpers 1-3 for microfone, 5-6 for audio L and 9-10 for audio R.
I've bee searched thru internet and didn't find this trick anywere.
Feb 24, 2013 | HP Compaq dc7600 Convertible Minitower PC...
Card reader won't work
Hello did you install the driver for the card reader ???
If not you can find the driver here at HP:
http://www8.hp.com/us/en/support-drivers.html
Seach by model and number, and select your windows system.
Check also the bios settings.
Try also to find the manual.
Good luck
Jan 24, 2013 | Computers & Internet
Need a new power supply for a soyo mother board Crown model fp-
All you need to know is if your motherboard has a 24-pin or 20-pin power connector. You can just count the pins if you don't know. There connector is located on the motherboard. It looks like this: moondogwst75_3.jpg
So if it's a 24-pin, order a 24-pin power supply. If it's 20-pin, order 20-pin. Hope this helps!
Aug 28, 2011 | Computers & Internet
I'm working on an Emachines T3624 I took out the front panel connectors and I can't remember where the power switch connects to the motherboard. I know the general area but I don't know the exact spot....
The manual can be downloaded here, just click on "drivers and downloads" and follow it out.
http://support.gateway.com/us/en/emac/default.aspx
I was hoping to refer you to the manual to provide a diagram, but the manual does not show the front panel I/O connections, so I'll give you general instructions.
The front panel header is a set of two rows of pins. You may need a magnifying glass and flashlight to see the small print on the motherboard that identifies the pins. Look at your front panel cables and look for the same abbreviations on the circuit board. You should see "pw sw" (power switch), "rst" (reset), HDD (hard drive activity indicator LED), and "pw" (indicator LED that shows that the computer is powered up. There should also be speaker.
Just match the cables to the pins on the motherboard. Polarity ( + or - ) is only important for the LED's ( pw and HDD ) Don't worry, if you connect them wrong, they just won't work, just swap wires.
Apr 29, 2011 | E-Machines T3624 PC Desktop
Audio Panel HP DC 7700 Minitower case with Hp 7600 motherboard
just change the placement of pin 7 to pin 4, but its only to solved the error massage, the front panel audio will not work properly e6f61c3.jpg
May 27, 2010 | HP Compaq dc7600 Convertible Minitower PC...
I would like to move it in to a bigger case
When looking at the specifications of the HP Compaq DC7700 SFF Desktop PC, all they state is the motherboard form factor is, 'Custom'.
Same thing for the DC7700 USDT Desktop PC.
Both of these desktop computers are of the 'Pizza Box' design.
(Flat rectangular box)
The DC7700 CMT model is a tower model, and the motherboard form factor for it is uATX.
uATX can also mean Micro-ATX.
The form factor of a Micro-ATX motherboard is 244mm by 244mm, or also said as 9.6 inches by 9.6 inches.
(9.6 inches is approximately 9 and 9/16ths inches)
To regress for a moment, and explain the term Form Factor.
This term is supposed to apply only to motherboards, but has gone on to apply to computer cases, and power supply's.
Form factor means the dimensions of the motherboard, and also where the I/O area is located.
[I/O = Input/Output
Area for the Input/Output devices that are attached to the computer.
Examples: Mouse, Keyboard and Monitor]
Whether the motherboard is installed onto the Left side of the computer case, and the I/O area is on the Left side also (ATX , Micro-ATX, and uATX form factor),
or
whether the motherboard is installed on the Right side of the computer case, and the I/O area is on the Right side also. (BTX)
Dimension sizes:
ATX is 305mm x 244mm. (12 inches by 9.6 inches)
Micro-ATX is 244mm x 244mm (9.6 inches by 9.6 inches)
http://en.wikipedia.org/wiki/Computer_form_factor
Above the link is the Maximum size for the Micro-ATX form factor.
It can also be the Minimum size of 171.45mm x 171.45mm
(Or 6.75 inches by 6.75 inches.
6.75 inches = 6 and 3/4 inches)
http://en.wikipedia.org/wiki/MicroATX
Point of all this?
The motherboard form factor inside a DC7700 SFF is probably a uATX form factor, and is 6.75 inches by 6.75 inches.
Or some variation thereof.
It's a custom size.
This means good luck in finding a computer case you can buy off of the shelf, and is large enough to install an ATX power supply.
You can get a custom one made, and you're probably looking at $150 to $200.
Or, you can modify one of these computer cases VERY easily,
1) http://www.directron.com/cs888uvbl.html
The above is an Acyrlic plastic computer case. It's approximately 1/4 inch thick for the case walls, bottom, and top.
VERY sturdy.
It has metal Standoff's that are set up for an ATX motherboard.
It should have holes in the case where a Micro-ATX motherboard can be mounted, by unscrewing the Standoffs, and screwing them into the Micro-ATX holes.
[A Standoff is a piece of metal that is hex shaped, and has a threaded hole in one end, and a threaded end on the other side ]
If there isn't the proper holes for mounting your motherboard, you make the holes.
The case is plastic.
Uses an ATX power supply.
The cost of the case is $50
Mar 08, 2010 | HP RT810UTABA - HP dc7700 small form...
Sound Drivers for HP MotherBoard
Here's the download site for yor machine. Choose your operating system and the whole set of drivers will come up.
Good luck.
Ron
May 16, 2009 | Intel Motherboard
Hp dc7700
verify you device manager if there is modem or network card installed, if you see a device with yellow question mark..it means you need to install the right driver
network card are built in to motherboard...maybe the right driver is not installed.
you can verify the original configuration by going to hp web site support and type the product number..
Mar 15, 2009 | HP RT810UTABA - HP dc7700 small form...
Computers & Internet Logo
676 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
