Question about West Bend 85146 6-Quart
Displays E 01
When I push the button to turn it on it displays E 01.
  • 2 more comments
  • Phyllis Sydoriak May 17, 2007
    I have a westbend crockpot that I have only used 3-4 times. I went to use it this morning & when I push the botton to turn in on it displasy E 01.
  • Anonymous May 11, 2008
    How do I correct the crock pot when E 01 shows up?
  • clthbj Jan 16, 2009
    I have a West Bend 84386 and when I turned it on this morning it had E01 error when I tried to set the temp. How do I correct this? Need this now, I have a dinner today with my recipe in the pot. HELP!!!
  • mandaluv2006 Feb 21, 2009
    i have the West Blend 6 QT slow cooker, 84368. when i plug it in, it beeps like it is suppose to, to let me know that it is on, but as soon as i push any button it make a loud beep and E01 shows on the display screen, now it wont do anything at all! please respond and help me figure this out!
    Amanda
Talked to the nice lady at West Bend. Apparently, the problem comes up when the unit is "cold"... whatever that means. She said to plug it in, wait a second, then push the power button, then "cook" immediately. No pause. Don't hold either button. I tried it, it worked on mine.
Apparently, this a feature for some reason.
Posted on Jan 19, 2009
The thermostat may temporarily lose calibration due to temperature changes resulting in an EO1 error message on the display. Repeat the following steps to reset the unit.
1. Unplug the unit from the wall socket for approximately 10 seconds.
2. Plug the unit back into the wall socket.
3. Once plugged in, press the POWER button once. Within one second after, press the COOK button once.
Posted on Jan 02, 2010
    Sergeant:
  • 274 Answers
Check out West Bends link: http://www.westbend.com/westbend/catalog.cfm?dest=dir&linkon=section&linkid=5 Your answer is there.
Posted on Aug 27, 2007
Why is all lights flashing on display but wont respond by pushing buttons.. keeps beeping??
Unplug it, wait 15min replug and start again..the lights should indicate the high and low temp long or short time , and then of course warmer ..sometime high and low as well
Good luck
Aug 14, 2014 | Crock Pots & Slow Cookers
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
I need an owners manual for the SCVC651
I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
"Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
Hopefully, this helps answer your questions!
Nov 23, 2010 | Rival SCVC651-F Slow Cooker
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
My smartpot shut it self off and wont turn turn back on
try holding the reset button down, plugging it in, and then releasing it after maybe 5-10 sec.
if your familiar with computers.... try repeatedly pushing the reset button as you plug it in... kind of a total reset
other than that it sounds like a glitch.... how long have you had it.... Mmm, consider calling the company and explaining complete mechanical failure. Hey, you never know if you don't try. Happy Holidays... best of luck
Dec 24, 2008 | Rival 38601 Smart Pot 6-Quart
How do I get both 8 hours time and high setting on this crockpot?
I got it on high for 1 hour and then reset it to low for 7 more hours and everything appears to be fine. I suspect that this crock pot runs at a little higher temperature. The *low* setting seems as hot as my older crockpot on high...... With this crock pot - set the hours while turned off with the right button and then turn it on. You may have to play with it several times to get the proper heat setting. As I said, I could only keep on it *high* for 1 hour.
Nov 22, 2008 | CorningWare SC60 Slow Cooker
Display on digital reading
The site for West Bend is www.westbend.com you can read the FAQ to see if you problem is there or you can e-mail them with your problem.
Dec 21, 2007 | West Bend 84716 6-Quart
West Bend 85146 6-Quart Logo
648 people viewed this question
Top West Bend Crock Pots & Slow Cookers Experts
Steve
tsalagi152
Sloop Johnb
Are you a West Bend Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
