Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Westell 327 modem is listed on itouch; itouch asks for password
Westell 327 gateway is working.
itouch sees it and I see 3 bars on my itouch. A lock appears next to the name of my network, but then itouch asks for password. I tried using the westell password I set when I reset my username and password (after using the westell username and password to get started)
When I typed in my newly set password on my itouch it did not work. I am thinking this is not the password that itouch is looking for???
Or should I use the password that is attached to Key 1 when I got into Westell privacy settings? (I tried that but it did not work)
Are there other settings on the Westell 327 that I should insure are correct so my itouch will connect?
I am a beginner, all help is appreciated... Thank you!
  • 1 more comment
  • ewayz7 Jan 11, 2009
  • Sara12345678 May 06, 2009
    I have the same problem. Is it possible to change my password? If so, how?
  • Anonymous May 18, 2009
    I kinda have the same password , but I found out
    Westell doesn't wait for the itouch because it's wired meaning it's a modem and wireless network.
  • 192 Answers
Lock on the botom of the router it might be locking for the WEP password on the label
Posted on Jan 04, 2009
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
What Is The WEP For A Westell Modem, Model 7500 A90-750015-07
The WEP key is located on the silver label on the bottom of each unit under the Serial Number and is clearly marked on my unit.
Mar 21, 2009 | Computers & Internet
Westell model 327w router
if this is the first time you're trying to connect your laptop with the gateway, if this is a windows operating system, you have to go to your wireless zero configuration so that windows can automatically configure the wireless connection of your laptop. you cann see that by clicking on start, and then run, and then type in the box services.msc, and then search for wireless zero configuration click on start if the service has not yet started. if this doesn't work check your built in wireless adapter, uninstall and reinstall it. try to access your westell by typing in 192.168.1.1 in the internet explorer address bar. the default username and password for that is admin and password. you can configure the wireless settings in the modem by going here. the WEP key for your wireless connection can be found below your westell modem/router. if i'm not mistaken this is the westell 327 versalink right? you can also find out if your laptop is connected to your modem by checking your computer's ip address. it should be 192.168.1.xx. if it's like this, your laptop is connected to your 327w. if it's a 169.xxxx ip address, you're not connected to the modem. the best way to configure your laptop and modem wirelessly is to configure it while you're connected using an ethernet cable.
Oct 21, 2008 | NetGear DG834G Router
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Westell Versalink, model 327W
if you are using the USB port of the modem, you should be able to see your modem while you are online, but if you are connect through ETHeRNET, you wont be able to see the modem on your device manager.
here is a USB port
and here is an ethernet port
Aug 12, 2008 | Westell Wirespeed VersaLink...
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
May 21, 2008 | Westell Wirespeed LiteLine 6100...
Cannot connect using westel 327 from verizion --lights blinking(dsl)
If they are charging you for the use of the westel, just tell them you don't need it. I would keep using your other modem that works.
Jan 28, 2008 | Westell Wirespeed VersaLink...
Itouch with verizon dsl
powercycle the modem and try.
Jan 05, 2008 | Westell Wirespeed VersaLink...
Default Password
the default password for your westell 327 is username: admin and password: password, the admin admin combination is what usually isp providers such as verizon tells you to put in after configuring it for the first time. 192.168.1.1 is the url add for you to be able to access your westell 327. after accessing your modem you can find the WEP key below the modem, after enabling the security of your network the WEP kep is your default security password
Dec 12, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
723 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Carlos Soto
Carlos Soto
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
