Question about Westinghouse Refrigerators
I want to remove door handle on model RS663V*7 side by side westinghouse refrigerator?
Model RS663V*7
Thanks Tyler T and L fortunato. I just gently but firmly gripped the handle with both hands and pulled it up and it popped out. Wear some rubber gloves to gain more grip. No card required. Now I know what parts to buy. They are all small plastic pieces attached to both the handle and the fridge door itself.
Posted on Jun 10, 2013
  • 30 Answers
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
SOURCE: The handle on my refrigerator door (Admiral side
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Posted on Dec 30, 2009
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
  • 15 Answers
SOURCE: door handle is loose on model#gsh22jftacc. how do you tighten?
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them.
It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
Posted on Mar 03, 2009
alex_salve
  • 78 Answers
SOURCE: 2000 Kenmore Refrigerator 10659502993 I am looking for used door handles in white.
please buy new one! please
Posted on May 25, 2009
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Door handle clips replacement
iam looking for doors handle barcet for model no RS662V westinghousetwo door frigde freezer
Apr 16, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Dimensions
This model is a 25.6 Cu. Ft.
Height to Top of Hinge: 69 1/4"
Height to Top of Case: 68 3/4"
Case Depth w/o Door: 28"
Case Depth less Door Handle: 32 1/4"
Case Depth w/ Door Handle: 34 7/8"
Depth w/ Fresh Food Door Open 90°: 50 1/16"
Width: 35 3/4"
Width w/ Door Open 90° w/ Door Handle: 42 3/8"
Air Clearances - Each Side: 1/8"
Air Clearances - Top: 1"
Air Clearances - Back: 1"
Approximate Shipping Weight: 360 lbs.
Capacity
Total: 25.6 cu. ft.
Fresh Food: 16.02 cu. ft.
Freezer: 9.59 cu. ft.
Shelf Area: 22.4 sq. ft.
Dec 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sears Kemmore Mode; Refrigerator side by side model 106.9557621 How do remove door handle
The upper and lower trims have to come off for access to the handle screws. Some just slide up or down and some have screws on the top and bottom of the door. Carefully pry them off.
Eric
Jun 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I want to remove door handle to replace broken fixture.
I think you may have to remove the door gasket, if you look behind the gasket you will see the screws holding it and the inner door liner in place, both should be removed and you will then have access to the handle screws from within the door.
May 27, 2009 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Broken door handle
The fresh food door handle is part number is 218668401 and the freezer dor handel is part number is 218668401 same number. Visit my web page and enter your refrigerator model number WRS6R3EW1 or mthe door handel number
218668401 in the model or part search feature. Below is the like to my web page. (Click on link below)
http://servicepartstec.blogspot.com/
Thanks, Sea Breeze
Mar 26, 2009 | Refrigerators
Refrigerators Logo
236 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
