Question about Samsung SyncMaster 910MP 19" LCD Monitor
Samsung GH19LS LCD Monitor wont display computer signals
The monitor turns on, displays the message "Analog" then "Digital" about 6 times and then the monitor turns itself off. A pressing the menu button on powerup shows the message "TEST OK", but the issue is that when the monitor is plugged into a PC, 2 pcs and 2 laptops have been tried, the monitor does not display any computer generated image.
Since the backlight powers up, and the monitor displays the messages on the screen, I also tried a couple different cables between it and the computers, but nothing different. Can anyone provide some idea as to what this problem may be?
  • 1 more comment
  • exmods Jan 09, 2009
    Thanks for your comment. I have since contacted Samsung, and discovered another person with this same problem. It turns out that this is a common problem with this model, and stems from the video driver board going faulty. The monitor is 6 months out of warrenty and it will cost $55 for them to look at, and possibly $140 more to replace the video board. I am dissapointed, since this monitor seems to actually work, but wont display the picture of the incoming computer screen. Both the DVI and VGA connectors are effected by this problem.
    I think that I am now asking for assistance, with the expectation that a hardware solution is required. :( But I am not adverse to this possibility, if someone has guidance.
  • Starfish Phoenix Apr 21, 2009
    I have exactly the same problem with the same LCD. As for a different input cable, No such luck here, Looks like I got the cheaper model with only vga input!
    I'm looking into the controller board problem and will post as much advice as I can if I can solve this problem.
  • Starfish Phoenix May 11, 2010
    I have this LCD open on my desk, It is the controller board. I'm googling for spares using the part numbers and nothing! ... Not a sausage! Whereas my Xerox xm7 19w I can find spare parts no problem!
    Any ideas where I could find spares?
    President:
  • 8,637 Answers
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Posted on Jan 09, 2009
Display on left half is correct and right half is slightly faded
Uninstall reinstall drivers from Device Manager of Display or check out for video card defects
May 30, 2010 | LG 22" FLATRON LCD Monitor
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
When the monitor is turned on it displays "analog, digital" then "check signal cable", what is the problem?
check the data cable from the CPU to the monitor, it measn the monitor did not detect any signal from the CPu, or the system is not booting. Good luck
Sep 11, 2009 | Samsung SyncMaster 932B LCD Monitor
LCD display turns pink then goes off
You may be blaming the wrong device. I suggest you try the monitor with another system, the problem you describe could be located in the video output of your system instead of a monitor fault.
Feb 28, 2009 | Samsung SyncMaster 920WM LCD Monitor
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Samsung SyncMaster 910MP 19" LCD Monitor Logo
3,501 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
