Question about Magellan RoadMate 700 GPS Receiver
Magelllan GPS Good morning. On my Magellon GPS (that I plug into the cigarette lighter in car) I plug it in and it comes on for a minute then shuts off. I wiggle the cable at the magellon end and it comes on for a second. I went to radio shack and got a new cord, same thing, use my house cord and same thing. The little pronge in the unit does not feel loose. Any suggestions? Thanks, Scott
  • Scott Kauffman May 18, 2007
    Thank you, I ordered a new craddle on line and "hope" this does the trick. Every place currently has the cradle on back order and will take a few weeks to see if it works.
    Scholar:
  • 121 Answers
Sounds like the pronge on the unit might have come loose from the print, or the pronge is damaged internally. It might still feel like it's properly attached, though. I've steen the same problem of several other types of electronics. (Laptops, electronic pianos and so on) I'de get an electronics serviceman to check it; it's probably a bad connaction in the pronge or from the pronge to the circuit board.
Posted on May 18, 2007
My 2007 streetglide continually blows the 5 amp fuse when I run my magellon gps off the cigarette lighter. I have replaced the fuse with a 7.5 amp fuse and the problem continues. I have been told that I...
Most cigarette lighter circuits can handle up to 20 amps of current draw. Go over that and bye bye fuse...The lighter itself will draw 10 amps when it creates a direct short to heat up. As you can see. a 5amp is useless.
Jul 21, 2011 | 2008 Harley Davidson FLHX Street Glide
When using wire in car, Garmin won't turn on, it starts, shows a low battery sign and shuts down. Was working fine on recent trip. It seems no power is reaching GPS. Nuvi 765T
Most likely the fuse in the charger plug has blown. The plug that goes into the cigarette lighter socket has a ring near the end. On most chargers it's silver but some of them are black. If you unscrew this ring the plug comes apart. Be careful not to lose any parts. You'll see the fuse in there. Replace it and it should be ok.
The other possibility is that the cigarette lighter socket is not working. You can check that easily enough by trying something else in it.
Oct 14, 2010 | Garmin nuvi 765T GPS Receiver
Porsche cigarette lighter is bigger than standard cigarette plug
Found a cigarette lighter assembly that is the standard DIN/SAE size that is a direct replacement for the one in my car.
Aug 31, 2009 | Garmin zumo 550 GPS Receiver
Where can I download free maps for my Magelllan RoadMate 1200?
go here //downloadanystuff.org/ put your download query and search
Jun 08, 2009 | Magellan Roadmate 1200 Car GPS Receiver
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Auto shut down screen does appear when ignition is turned off
This is telling me that your cigarette lighter socket has +12VDC applied to it all the time EVEN when the ignition is turned OFF. This is not the fault of your Nuvi. On some cars, like Hondas, the cigarette lighter socket powers off when your ignition is turned off.
If you want it to turn off with the ignition, then you will have to power it from a +12VDC source that is controlled by the ignition.
- Jim
Nov 28, 2008 | Garmin Nuvi 660 GPS Receiver
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
91 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
