Question about Toshiba Satellite A105-S4364 (PSAA9U0VE03D) PC Notebook
Synaptics pointing device ceased to function
My notebook is toshiba model satellite,windows vista basic.,a 135-s-2246.my synaptic pointing device stop to function.i downloaded and install from toshiba web site but still the same is not functioning.pls.provide me a possible solution.
thanks,
ely my touchpad isnt listed in my device manager and wont connect to the driver
  • 144 Answers
Load up device manager , highlight your computer (top in the list) and right click - select scan for new hardware - See if it detects your pointing device now
If it does , right click it , update driver etc and reinstall the drivers for it
If not , it might be a hardware problem , try getting it repaired by toshiba if its still under warranty
Posted on Jan 04, 2009
Problem with the HP G60-235DX PC Notebook Notebook Touchpad won't scroll. (Synaptics) Previously it would scroll with no problem, then suddenly quit. How do I restore the function? Previous...
Have you checked the settings of your synaptics? Usually there's an Icon on the taskbar for synaptics you can right click it and check if "disable touchpad if usb pointing device is present" is checked, if so uncheck it then your touch pad should work again.
Here's a link for a step by step instruction though this is for windows xp but steps are the same. Hope this works for you:
http://blueboxagency.com/helpdesk/?page_id=16
Apr 10, 2011 | HP G60-235DX Notebook
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
My synaptic pointing device stop working ..I think
Since you do not specify the model number for your HP laptop one cannot be too specific. On my Toshiba laptop activation and deactivation of the touch pad is enacted by pressing the Fn-F9 sequence.
The actual Function key to press after the Fn key might have the picture of a touch pad on it. Examine tour laptop keyboard.
Jul 06, 2010 | HP Computers & Internet
Synaptic pointing device is not working
As the Synaptics Pointing Device is not working , you need to install the driver for the same..
If you are using Windows Vista 32 bit as OS:
The link is :
ftp://ftp.hp.com/pub/softpaq/sp34501-35000/sp34535.exe
Install the driver and restart the computer to check the functionality..
Regards
KEN
May 13, 2010 | HP Pavilion dv4z Notebook
A135-4257 touchpad stopped working
Check to see the make of your touchpad (in most cases it would be a synaptics one.) If so, go to http://www.synaptics.com/support/drivers and download the corresponding driver according to your operating system.
NOTE
I'm assuming you already went through the basic steps such as checking if there's a dedicated touchpad button which might be turned off, checking if from control panel\mouse the device is not disabled, etc.
Nov 13, 2009 | Toshiba Satellite A135-S4527 Notebook
Touchpad does not function
It sounds to me like the touchpad drivers are corrupt and need reinstalling.
Go here to Toshiba support, download and install the touchpad drivers and utility and see if that helps.>>>>>>
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1845344&rpn=PSL48U&modelFilter=L45-S7419&selCategory=3&selFamily=1073768663
Good luck and please post back if you need anymore help or advice.
Regards.
Aug 17, 2009 | Toshiba Satellite L45-S7419 Notebook
Ok, concentrate some updates both of the operating system and of devices on occasions they generate conflict with other devices, I recommend to you to stop the updates of the Win Vista and first to check that same this activated, in the equipments toshiba is enabled by the key sequence Fn +F9 If even the fault persists, I invite you to that you reinstate the driver of this form it must operate.
Jan 14, 2009 | Toshiba Satellite A135-S2246 Notebook
Check Device Manager to see if the trackpad/mouse is listed. Check BIOS menu not disabled Check you have no 'palm-check' hot keys which disables the trackpad (to avoid moving mouse when you are typing)
Jul 22, 2008 | Toshiba Satellite A135-S2246 Notebook
Synaptics touchpad not working
that can happen..there's a connector under the keyboard, that may have come loose or disconnected
Mar 02, 2008 | Toshiba Satellite M35X-S349 Notebook
Touchpad not working
your synaptics driver may be corrupt, go to my computer>right click>properties>hardware tab>device manager, the nlook down the list for mice and othe pointing devices. Click on the '+' sign and on the synaptics line, right click and select uninstal. Restart the pc and then the driver should reinstall automatically, then give it another try.
Aug 14, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite  A105-S4364 (PSAA9U0VE03D) PC Notebook Logo
196 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
