Question about Canon Cameras
How do I set the date & time on a Canon MP121-MG printing calculator?
Lost the manual and not sure what function keys to use. Can change the date but not sure how to set it?
informatica
  • 1114 Answers
SOURCE: Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 17, 2007
SOURCE: Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Posted on Feb 05, 2008
old marine
  • 1973 Answers
SOURCE: Canon Pwershot A720 Date and Time Function
If you are trying to get the date/time displayed in your images, you need to set the recording size (L, M1, M2, M3, S, Postcard) to Postcard. You also need to turn the Date Stamp on in the Recording Menu (Use the Menu button, select the recording tab -- silhouette of a camera, and scroll down to Date Stamp).
Posted on May 28, 2008
SOURCE: I set up the date
FE 280 does not have the option of printing datetime stamp on the photos. As it will affect the resolution they did not provide this option.
Posted on Jul 20, 2008
t00nz
  • 4738 Answers
SOURCE: I have a Canon Powershot
The camera's clock battery has worn out. On the bottom left side of your camera is a little grey plastic slide door. Use your fingernail to pry it open and remove the CR1220 battery (pay attention which side goes up). Take it to the battery department of your local drug store and buy a replacement. It's a very common battery and should only cost around $3.
Posted on Sep 14, 2008
How to date change in camera for display see date
Switch on the cameraPress MENU at the back You will 2 icons. One for camera and other for tools. Select tools settings
Scroll down to Date & Time settings. Press Set/Function. Change the date and time as per our time zone. Press again Set/Function. For display of date Select camera icon and on the drop down menu select display. By pressing the function key select the date /date and time. Press Set. The camera is set. Whenever you view picture it will display the date and time
Apr 26, 2010 | Canon IXUS 80 IS Digital Camera
Setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Feb 02, 2010 | Sharp EL-1197PIII Calculator
I don't have the manual for my canon p23-dhv calculator. How so you set the date?
Hold down the time set key (M+ key) for 3 seconds. Then hit the date/time key. Enter in the correct date. Hit the time set key again to set. To set the time hit the date/time key twice to bring up the time.
Hope this helps.
Oct 30, 2009 | Canon P23-DHV Calculator
I am trying to set time and date on a calculator
OK, I bought one over the weekend just for chuckles. I figured it out.
On the top of the calculator there is a key that shows a little clock. Punch it once and the date appears...like 01-01-2000 or somesuch. Press it again and the time shows up..
Hold the time set key (=) down for a second until the first zero starts to flash. All you have to do is start punching in the time. When you are done press the time set key again. Voila!
Punch the key with the little clock again and the date shows up. Hold down the time set key for a second like explained above until it starts flashing. Enter the date with the key pad numbers. Done!
I couldn't figure this out either till I looked above each key (didn't notice what it said). Anyway, look real close.
Hope it works out for all and everyone finds this solution...
CMHIMG
Mar 04, 2009 | Canon P200-DHIII Calculator
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
Feb 29, 2008 | Canon LS-100TS Calculator
Nov 30, 2007 | Canon P23-DH Calculator
Canon p23-DH V
Slide the on/off switch all the way to the left to the "Rate Set" position. Now enter the appropriate tax rate. When entered, slide the switch to the desired "On" or "Print" position and CE/C before your first calculation. You should now be all set to go.
Oct 10, 2007 | Canon P23-DH Calculator
Cameras Logo
221 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
