Question about Linksys Wireless-G WRT54GS Router (e125894)
Linksys router i just bought a wireless linksys router so i can play xbox live. i followed all of the steps but i could not configure it. I then realized that my Arris modem is USB but it has an ethernet spot on the back. I have been trying many things to try to make my internet on my computer work and my xbox live at the same time, but either 1 or the other works, not both. Can you please help me.
  • 55 Answers
You haft to set the router to be static for the Xbox IP. in the settings you can sett it for gameing. just click on the gameing tab
Posted on Jan 10, 2009
I have a Verizon Wireless DSL Modem/Router GT704WG and I want to know how I configure my NAT type from strict to Open so that I can play Xbox live better with no restrictions
you can try to follow these steps,hope these works
1. Log into router's IP address ( and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again.
thanks and God Bless
Jun 29, 2010 | Verizon Communications Ethernet/Wireless-G...
How to connect to xbox live with linksys router
Just to confirm you are using a wireless connection to hook up to the router? do you have the router model number? Have you configured the correct wireless settings on the 360? Make sure that if you have a key that you have entered it correctly.
also you can use the xbox support site for reference, use the left side panel to look at wireless settings and other help.
Thank you,
Oct 21, 2009 | Microsoft Wireless Network Adapter Xbox...
XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
Aug 17, 2009 | Linksys Wireless-G WRT54G Router
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Linksys Router
it might be asking for a WEP password which is located on the botom of the router
Jan 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys router and modem problems
Most cable company's will not allow you to use the USB and the ethernet connection at the same time. You will need to only use ethernet to your PC and your XBOX. Once you have the ethernet cord connected from your modem to the WAN/Internet port on your router you will need to press the reset button on the back of the arris to authorise the router for access. After that is done you will plug you XBOX into 1 of the 4 numbered ports on the router. Then you will need an additional ethernet cord for your PC.
Hope this helps
Jan 04, 2009 | Arris SURFboard SB5120 Modem
Linksys router
unless your computer has an ethernet card it is not going to work, so if your computer is usb then you will need to purchase an ethernet card for it.
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Linksys Wireless-G WRT54GS Router (e125894) Logo
91 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
