Question about Westinghouse Refrigerators
Year westinghouse moist cold 501 Fridge manufactured
5 Suggested Answers
mpcheeseman1
  • 1400 Answers
SOURCE: Ive had my westinghouse moist cold 421 for quite a
The drip tray is all the way at the bottom.Pull of the grill at the bottom of the refrig,tray should be there.
Also there is a hole or tube under your crispers,check that its clear and not clogged with junk.
Posted on Jan 20, 2010
caroldon
  • 17130 Answers
SOURCE: I have just bought a
If you have the food frozen or water frozen in less than 2 hours with less opening of the doors then the fridge must be working fine. make sure there is sufficient voltage as required for the specified mains requirement.
Similarly once the freezer is working fine your bottles kept within should be chilled by this time.If so your fridge seems to work fine.
Since you have a new fridge you can always have the warranty/service cover which you must be aware of and taken consent for advice..
Posted on Dec 30, 2010
sonicboomele
  • 1557 Answers
SOURCE: Hello the westinghouse fridge i
six is the coldest setting 1 is the lowest
Posted on Feb 16, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Westinghouse Moist
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on May 06, 2011
Year of manufacture? Westinghouse fridge
Contact Westinghouse customer service with your serial number.
Nov 22, 2014 | Westinghouse Refrigerators
I have a Westinghouse Moist Cold Cylic Defrost refridgerator the freezer is great but my fridge area is on the lowest setting but is freezing my food, ,Why is this ?
heatman101
May 02, 2011 | Refrigerators
Do I want low or high humidity to keep vegetables crisp. Neither seems to make much difference.
The humidity switch does not control the humidity inside the fridge, but rather is used to control moisture that can form on the edges of the fridge and on the divider between the fridge & freezer compartments.
In areas that experience humid conditions, this is a common occurrence. The relative cold of the freezer & fridge in certain areas of the fridge case causes moist air to condense on contact. This condensation is prevented by a heater that is behind the metal case of the fridge. The moist air can't condense because the metal surface is warmer than the room air.
If you don't have a humid time of year, leave the switch set to "off", as the heater uses electricity and lowers the efficiency of the fridge and freezer - resulting in increased cost of operation. Not using the heater when it is humid will eventually cause the moisture to cause rust on the wet areas of the fridge case.
Please rate this reply - thanks!
Dec 01, 2010 | Sub-Zero Refrigerators
Ive had my westinghouse moist cold 421 for quite a few years and lately there has been at times water leaking at the inside under the vegetable cripsers . I'm unable to find my user manual but I recall...
Jan 20, 2010 | Westinghouse Refrigerators
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
