Question about HP Computers & Internet
Need a hard drive for hp a810n
Pavilion a810n
SOURCE: WRONG CONFIGURATION/BLACK SCREEN/HP PAVILION a810n
if it is in warranty i would suggest you to call the hp guys .... if out of waranty please post the exact error message
Posted on Sep 12, 2007
The-Only-Sol
  • 144 Answers
SOURCE: can not get my cd dvd writer to open on my hp pavilion a810n
If no lights shown on drive, Check if power conncetor is rightly & securely connected to drive. try with other connector.
If still the problem persists, change the drive
Posted on Jun 27, 2008
bunnydawg
  • 5158 Answers
SOURCE: i have a HP Pavilion a810n
do you mean an external drive for backing up your files ?... if so any usb external drive will work...of course larger then the hard drive you are backing up.
Robert
Posted on Jan 10, 2009
  • 1481 Answers
SOURCE: Need to install a new hard drive on a HP Pavilion
in most PCs the MB and cables inside will have provision to add
2 HDDs
2 Drives (CD or DVD)
1 floppy drive(now it's obsolete)
in a IDE system the data cables inside will be aprox 3 inch wide and the MB will have 2 IDE slots to fix the cables....
in a SATA system the data cables inside will be aprox 1 inch wide and the MB will have 4 SATA slots to fix the cables....from 2 HDD and 2 Disk Drives....
you should know how to install a new HD and make it primary or slave depending on which HD has your OS...
google and find more details on that...
Posted on May 04, 2010
ghost2233
  • 3606 Answers
SOURCE: need ethernet driver for hp pavilion 725n also
You can down load the driver from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=311249#N228
good luck.
Posted on Mar 10, 2011
I have a soild yellow light
That is the HDD light or the hard drive activity light. There must be something accessing your hard drive. Is there a problem with the PC like slow speed or booting?
Aug 28, 2011 | HP Pavilion a810n (PP164AA) PC Desktop
Replacing power supply to hp pavillion a810n and don't know how to connect all the wires. we bought dynex 400 watt power supply.
The secret: all the wires are oriented (you cannot plug the in backward), and your replacement
power supply must have a connector for each of your peripherals.
Even the connector going to the motherboard is oriented.
Make sure everything on this list has a power connector plugged into it, then
power up the desktop system and compute.
1. motherboard
NOTE: everything below in the list resides in a peripheral bay
2. HDD (hard disk drive) (there may be several)
3. FDD (floppy disk drive)
4. CD-ROM
5. DVD-ROM
If you run out of connectors, buy a "Y-connector" at your local "Computer Goodies" store.
As you connect these devices try to utilize proper anti-statis techniques - meaning, if you don't have an anti-static strap to clip onto the Pavilion A810N frame, then be sure to ground yourself
by touching the frame with a forearm or something as you make/unmake the power connections,
while at the same time try to avoid touching the (CMOS-based) IC chips or PC board surfaces.
forearm
External drives (incl tape drives) get their own power - not from your 400W Dynex.
Your computer monitor will also gets its own power (from a 120VAC 3-prong CEE cord)
Mar 18, 2011 | HP Pavilion a810n (PP164AA) PC Desktop
I have an HP a810n desktop. First let me say that I did a backup of my system back in 2/10. Up until a few days ago it ways sort of o.k. Now when I try to turn it on it comes up with an error,...
Hi There,.
I recommend you work your way through this guide before attempting file transfer.
http://pcsupport.about.com/od/findbyerrormessage/a/stop0x0000007b.htm
The best way to recover the data you want is to remove the drive, install it in an external enclosure and read the file from another computer, saving them to flash drive or another external storage drive.
Regards,
Marcus
Sep 17, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
I have a HP Pavillion a810n that boots up part way then starts booting all over again. It cycles through the bootup cycle repetively. Any idea what is wrong? I have replaced the hard drive and there was no...
Try to F8 it into safe mode and check the device manager for conflicts. It is probably a device driver issue. It is a matter of finding the problematic device and then working toward a solution.
Sep 02, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
I need to restart my computer, but I lost my hardrive how can I restart
Lost hard drive???? I'm guessing ya didnt misplace it, it just dont recognize the hard drive? If a hard drive is bad, a pc will not boot past level one diagnostics. Replace hard drive.
Jun 12, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
PARTIONING HARD DRIVE
Make it slave and attach to the machine. If it is SATA, then attach it normally and change the boot order in BIOS.
Apr 11, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
I have a HP Pavilion a810n Desktop PC (AMD Athlon 64 3300+ Processor, 512 MB RAM, 160 GB Hard Drive, Dbl Layer 16X DVD+/-RW/CR-RW Drive, CD-ROM Drive) what back up ard drive is compatible
Robert
Jan 10, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
HP a810n will not boot up
On most HP's and Compaq's you can restore the machine by pressing F11 when you see the HP/Compaq screen when you first turn the machine on.
There is a hidden recovery partition on your harddrive and your machine will be restored to the condition it was in when you bought it, the only problem with that is it will delete any personal files you have on the machine like photo's and music.
If you want I can talk you through recovering your personal files before attempting the restore, it will involve removing your harddrive from your computer and linking it to another computer.
Aug 24, 2008 | HP Pavilion a810n (PP164AA) PC Desktop
Can not get my cd dvd writer to open on my hp pavilion a810n
Jun 27, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
