Dma controller error system halted - Computers & Internet
4 Suggested Answers
  • 256 Answers
SOURCE: dma error system halted what can i do to get it
Give us the (1) Manufacturer's or Computer's Name; (2) The Model name and number; (3) The ID for the motherboard and (4) A description of your experience with the failure, before failure, during failure and after failure. If you have a problem finding the info., we will help you. When we receive the information, we make a mathematical model of your computer and we duplicate the failure. So, when it comes to giving you instructions, we give you facts and not guesses. A big thanks for considering our service... My name is Constantin (arzconst is my nickname for contacting me at work).
Posted on Jun 13, 2009
  • 6 Answers
SOURCE: Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Posted on Feb 16, 2010
  • 11800 Answers
SOURCE: Asus P5RD-2-UM acpi bios revision
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Posted on Dec 20, 2010
Tip
Turn Direct Memory Access (DMA) on or off You must be logged on as an...
You must be logged on as an administrator to perform these steps.
is usually turned on by default for devices such as CD or DVD drives that support DMA. However, you might need to turn on DMA manually if the device was improperly installed or if a system error occurred.
  1. Click to open Device Manager. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Double-click IDE ATA/ATAPI controllers.
  3. Under IDE ATA/ATAPI controllers, for each item that has the word Channel as part of its label, right-click the item, and then click Properties.
  4. Click the Advanced Settings tab. Under Device Properties, select or clear the Enable DMA check box, and then click OK.
on Dec 14, 2010 | Computers & Internet
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Foxconn p4m800p7ma-rs2 motherboard on Gforce FX5500 system halted
You refer to Master/Slave disks. Are you actually using the Master/Slave jumper settings? Must motherboards and OSs today recommend putting the disks in the CABLE SELECT jumper setting. The problem with the old Master/Slave setting is that the Controller on the Master Disk is used to control the Slave disk as well. This can lead to problems when disks are made by different manufacturers, as sometimes they are not fully compatible. In CABLE SELECT, each disk controller works independently.
Dec 30, 2011 | Foxconn Computers & Internet
Asus P5RD-2-UM acpi bios revision 0811. Press del to run setup Press F8 for BBS popup initializing usb controllers..done. 992mb =32 mb shared memory avto detecting pri master ide hard disk pri master...
Dec 20, 2010 | ASUS P5RD2-VM Motherboard
блять заебали,...
My problem MOTHERBOARD ASUS A8V-VM se
DMA Controller Error
Fata Error ...System Halted
Best Regards
Andrew
mailto: best59@gmail.com
Jul 28, 2010 | ASUS A8V-VM Motherboard
When i turn comp on all i get is black screen that says intel desktop board and operating in dual channels paging mode dma error system halted . i tried to go to bias and to reinstall windows boot disk no...
try to first take of the cmos battery for a few minutes and them put it back and get in the bios and made the modificationes for boot up by the cd-rom and procedure to install fresch copy of wind...
try that . best regards italocub
Jun 10, 2009 | Intel D865GBF Motherboard
Dma error system halted what can i do to get it back
Agere All 56K Modem
I have checked the telephone line, it is working alright and it is sure that I have plugged the line into IN port.
Oct 19, 2008 | Agere All 56K Modems: 56K V.92 Lucent/...
DMA drive error.
Its a problem with the windows dma seting for drives. In "device manager", open properties for ur drive and your interface like IDE/ATA controller. There, you can check and change DMA Settings.
Allow max DMA. Do not disable DMA.
U can also check DMA setting on BIOS if ur bios supports it.
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
553 people viewed this question
David Payne
David Payne
