Question about Sony KDS-50A2000 50" HDTV
No volume Changed Lamp now no volume
I changed the lamp on my pt44-lcx65 panasonic tv and everything comes on great but red lamp light is still lit
Turn on the television.
  1. Press the volume down button on the TV display (not the remote!)
  2. While pressing the volume button, press the "split" or "PIP" button on your remote.
If it works, you'll see a message like this, an the lamp indicator light will turn off. Success!
May 30, 2014 | Panasonic PT-44LCX65 Television
Panasonic PT-43LC14; I changed the lamp. I still get the lamp meter warning on the screen when I turn on the TV. How do I reset the lamp meter?
terayamam001,
Here is the procedure,
1. Turn on the television
2. Press the volume down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or " PIP" button on the remote.
This should solve your problem.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I Changed the lamp, and would like to reset lamp timer. how?
hold volume down on tv and PIP on remote for 10 sec's at the same time.
Dec 16, 2009 | Panasonic PT-52LCX65 44" HDTV
How to reset the lamp timer count on a LG rear projection TV
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME (>) button.
3. Press the OK or enter button.
Lamp time will be reset.
Jun 15, 2009 | LG Televison & Video
Changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Apr 11, 2009 | Panasonic PT-52LCX66 Projection Television
Infocus lp 530
Hello, That should absolutely reset the lamp timer.
This is crucial: Press and hold the volume - button, then press the source button (while still holding down the volume - button) for 5 seconds.
Make Sure you hold them both down for 5 Seconds!
I hope this helps you.
Cheers
May 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
LP 530 Lamp does not power on
Did you cancell the bulb fault status in the main menu ie bulb hours when you changed your bulbs if not try this turn unit on and see if it works it may do.
To reset the lamp hours counter press and hold down the Volume minus button - , then press the source button whilst still holding down the volume button for 5 seconds .
If this works you can then verify that the lamp counter was reset by viewing the counter in the status window in the OSM
hope this helps... Regards Vortash
Feb 27, 2008 | InFocus LP 530 Multimedia Projector
Lg 44sz8r lamp clock
[1] Press the OK or MUTE button on the front panel of TV and the MUTE button on the remote control at the same time for about 5 seconds.
[2] Press the VOLUME button > button
[3] Press OK or ENTER button
Lamp time will reset - that's it.
Sep 12, 2007 | LG RU-44SZ61 44" Rear Projection...
Sony KDS-50A2000 50" HDTV Logo
15 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
