Question about Sears Home Security
My Sears model 41A4315-6D garage door opener will not close unless I hold the wall switch until it is completely closed. The door opens just fine with the remote. The door springs are well enough ba
Door opens smoothly, but trolly rocks back & forth (not side to side) when closing as I hold the wall switch. The problem began with intermittent door reversal, now always happens, and does not even get partway down any more. I also have a newer opener that has a box beam, not a T beam track.
jessee007
  • 306 Answers
SOURCE: door will not close
the eyes are a little bit out of adjustment
Posted on Jan 09, 2008
lobsterman72
  • 91 Answers
SOURCE: Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
  • 11 Answers
SOURCE: Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Posted on Jan 25, 2009
jyackle5
  • 8197 Answers
SOURCE: Garage Door Wont Close Craftsman 1/2 HP (1998)
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Posted on Mar 05, 2009
We have an Access Master garage door opener that will not allow door remotes to sucessfully close the door completely without holding the buttin down until door is completely closed and same with the wall...
Sounds like your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Mar 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opens fine when you puss the wall mounted button, but will only shut if you press and hold the button until it closes completely.
Check your door sensors. They both should have a small light that is lit and not flickering. Most likely one has been bumped and they are no longer pointed at one another. Tweak them a bit. If you can't get both lights on you most likely have a bad sensor.
Nov 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Okay, I'm having an issue with my Sears Craftsman garage door opener. Not exactly sure of the model number, but can dig it up if that's necessary. Symptoms: 1) Door opens fine from either wall button or...
It sounds like you have a problem with your wall button. I would remove the button from the wall and then disconnect the 2 wires on the back. Remember where they go as they are color coded. You can then momentarily touch the two wires together to check the operation. There isn't enough voltage there to bother you.
One thing to remember. If when the door reverses the main light flashes 10 times it is a door sensor problem and nothing else.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
May 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door will not close
Jan 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Open Questions:
Home Security Logo
108 people viewed this question
Top Sears Home Security Experts
Lawrence Oravetz
Are you a Sears Home Security Expert? Answer questions, earn points and help others
