Question about Electrical Supplies
I foolishly left the choke on my 1 day old Powerstroke 6000 generator in the start position all day and now it won't start... What do I do?
Mr. Worley you could never be more right!!! I had a similar problem (no start to my PowerStroke Generator 6000W). Added some Stabil, shook it around a bit and waited. Shook again and it started (after several pulls) runs like new. The only thing I noticed was the lever where you would slide to START has to be slid halfway between START and RUN, but please ask me if I care......NOT! as long as it runs! Side note: Oil, Spark Plug, Air Filter changed prior to adding Stabil (cause it can't hurt), I'm not that carefree!! Thanks Mr. Worley!!
Posted on Jul 01, 2014
3 Suggested Answers
  • 1267 Answers
SOURCE: My 4 year old Craftsman
Not that i am aware of, however, I suspect that as soon as you load it up it will die again as the load will call for greater speed, and too much fuel from the choke position will cause it to die again.
What I suspect is that your carburator is clogged up at the jets and is not metering the air fuel mxture properly. You may have to disassemble the carburator and clean it. Since the government has mandated that gasoline contain 10% alcohol, it has become a night mare for small engines that are not used very often. The alcohol is very hydroscopic (retains water) and during the off use period, the alcohol evaporates and leaves the water behind to mix with gunk and clog the needle valves.
Try removing the old gasoline. Refill the machine with fresh gasoline and add some "SeaFoam" (an additive) or any other brand additive that will help disolve the built up gunk in the carburator. Remove the air cleaner and try spraying a carburator cleaner down in the air intake while the machine is running, this way the air passages may clear while the new gasoline may dislodge the built up gunk. Note: The carb cleaner will stall the engine.
It is probably wise to run the gas tank dry before storage and only fill when the machine will be used. Stabil is an additive for storage, and it did it's job before the alcohol edict. I am not sure that Stabil will allow long time storage. (more than 3 months) SeaFoam can be purchased at WalMart, stabil is on the shelf of most small engine sales rooms such as Sears.
Posted on Jan 09, 2011
H2_Brad
  • 425 Answers
SOURCE: I did not start my
Old fuel will not make the engine lock up. While you will most likely need to clean the carb you should still be able to pull the engine over. Now the first thing to do is remove the spark plug and see if you can pull the engine over. If gas has drained into the engine there may be gas and oil in the head area. Do not stand in front of the spark plug hole when you try and pull it over just in case gas sprays out. If it still will not pull over then next remove the recoil starter and see if it is frozen up. With the recoil removed and the spark plug removed you should be able to turn the engine over by hand by grabbing the part that the recoil contacts, called the drive cup, that is bolted to the flywheel. Those are two somewhat easy things you can do to see if the engine is truly locked up.
Posted on Jul 19, 2011
Yamaha 5200d it starts and runs 2/3 minutes and shuts down oil is full low oil lite does not light up carb is clean
This generator is equipped with an auto choke. What is likely occurring is as the engine warms up the choke is returning to the normal choke off run position leaning the mixture two lean to maintain operation of the motor.
This is occurring because the residual fuel that was left in the carburetor has evaporated and the gum residue is reducing the fuel flow through the carburetor. When the choke is applied the mixture is rich enough to support running and as the choke returns on its own to the run position the mixture leans out and the generator stalls..
Override the choke when the engine is starting to falter to confirm the problem. Continuing to attempt to run the engine possibly adding a carburetor cleaner additive to the gas will likely return the unit to normal operation.
If attempting to enrich the mixture by applying choke when the engine begins to falter does not work then a fuel flow problem to the carburetor may be the root cause. I would look for a plugged fuel filter or restricted fuel flow from the tank to the carburetor. What is happening is when the unit is at rest the carburetor is filling with gas and as it is running because of a restricted fuel flow the level lowers in the carburetor bowl resulting in a mixture to lean to run.
Jun 01, 2014 | Yamaha Ef4000dfw/5200de/6600de...
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
Makita concrete saw, no spark, new ignition coil.
Check clearance between the coil and magnet, too far away and magnetic field won't generate.
Apr 13, 2012 | Makita DPC7311 73cc 14Inch Gas Powered...
Winco WC12000HE won't start...fired up last night and I'm getting nothing today.
Sounds like a fuel problem, check your filter if there is one. Check fuel in tank, make sure there isn't a valve off. Check your choke if you have a manual choke.
Sep 28, 2011 | Winco Industrial 10.8kW Portable ...
Have a 2005 homelite generator that I can not start. Have oil that was in before. Added gas. Flipped switch and hit the choke. Pulled chord and nothing.
Check the following:
1. The fuel - if old fuel was left in, it may be contaminated. Use fresh fuel. If the unit isn't used regularly, add the gas additive "Stabil" before storing the generator.
2. Check the air filter - clean or replace as necessary
3. Check the spark plug for fouling, gap, etc.
4. Make sure the carburetor is tight to the manifold and engine.
5. Make sure to start the unit with no loads connected.
6. Makes ure there is enough oil and the correct type in the engine - do not overfill.
Aug 27, 2011 | Electrical Supplies
Hi, my description is lengthy, but I tried to provide as much detail as possible for troubleshooting. I'm seeking technical input re: a continuing carb issue w/my '96 Magna, which would not turn...
Reserve tube is usually set at a 1 gallon level in the tank, if you only added a gallon to an empty tank,I would fill the tank at least half full, If that doesn't fix the issue then replace the petcock, It's not a carb issue if it runs fine in reserve.
Jun 28, 2011 | 1996 Honda VF 750 C Magna
It's almost brand new but i did not start it for about 10 months. Now i can't get it to start
the #1 enemy of generators or any outdoor power equipment. Old gas. It turns to gook that gunks up the works.
Jun 24, 2011 | Coleman Powermate Powermate 5000W...
Not used for 2 years. It will not start.
Engine will
not start
1. Low on fuel or oil. 1. Add fuel or oil.
2. Ignition switch in "Off"position. 2. Turn to "ON" position
3. Faulty spark plug. 3. Replace spark plug.
4. Choke in wrong position. 4. Adjust choke accordingly.
5. Fuel shut-off valve in closed position 5. Open fuel shut-off valve.
6. Unit loaded during start-up. 6. Remove load from unit.
7. Spark plug wire loose. 7. Attach wire to spark plug.
Apr 23, 2011 | Porter Cable 5,500 Watt Portable Generator...
Electrical Supplies Logo
968 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
