Question about Schwinn 430 Elliptical Trainer
The console does not work. E-2 shows up on the console.
Just bought a Schwinn 430 elliptical and the console ways E-2 when plugged in. It will not move to programs, heart rate or anything else. Has anyone else had this problem? How do I fix it?
  • egerard Mar 18, 2009
    I get the same message just a few seconds into the program and lose all settings - resistance, etc. I've tried pulling the power plug and re-inserting it, and hitting reset, but it does it all over again.
We had this problem after assembly as well, it turned out to be a bent pin inside the connector to the flywheel housing (where the wires connect inside the lower part of the main mast). It was so bent that it never actually made contact with the connector.
We straightened the pin, carefully reconnected the wires, and everything worked just fine.
This says to us that the "E-2" error message means the console is missing at least one connection from the system. This could be caused by a bent pin, a torn/cut/frayed wire, etc -- anything that might make it lose signal.
So check the lower connection for bent pins, check the upper connection for bent pins, and check all along the wires for any kind of damage.
Hope this helps!
Posted on May 03, 2009
  • doriagogo
    doriagogo Nov 06, 2012
    Is there a video anywhere that shows how to fix this? I too am having issues with the E-2 message. The unit is almost five years old and has done this from the very beginning. Lately, it's become more frequent and annoying.
Replacement batteries for Schwinn Airdyne AD3?
It should just be 2 AA batteries. Remove the battery door on the back of the computer to expose the batteries. Remove and replace. Computer Graphite Airdyne Big Fan Schwinn 92823 SPORTSMITH net
May 16, 2014 | Schwinn 430 Elliptical Trainer
Hello, I own a Schwinn Elliptical 430 which I keep outside, covered with a tarp, since 2011. It's been fine till now, the "Enter" button isn't responding so basically I can't use it because I can't move on...
HI,
Its probably because of the enter switch is not activating. Its contacts gone bad. There will be push switch behind the enter pad that you see from the top. you have to replace this by opening the Console, Display. if you are able to do the same please let me know .
Or just remove the Console, Display and take it to the nearest electronic rearing shop. They can do it very easily. and it will not cost a lot too.
Ajin
Aug 17, 2013 | Schwinn 430 Elliptical Trainer
Need manual for schwinn personal trainer 405 tread mill
Hello Brend
Please download the assembly manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_430_AM_RevB_web.pdf
Please download the owners manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_430_OM_RevA_web.pdf
Oct 10, 2011 | Schwinn 430 Elliptical Trainer
The power cord for my schwinn 430 elliptical no longer stays plugged into the machine. I have to push it really had into the bike outlet so the machine turns on, but as soon as I take my hand off of it,...
Do you think the power cord is going bad? If so here is the parts list for the Schwinn 430 if you need to order a new AC adaptor. If you think the connection inside the machine is going bad you may want to find a servicer to look at it.
Apr 19, 2011 | Schwinn 430 Elliptical Trainer
What is the output of the ac adapter for the schwinn 430 elliptical???
It should be at the bottom of the machine in the front facing away from you if you are on it.
Nov 02, 2010 | Schwinn 430 Elliptical Trainer
I have a 418 schwinn elliptical and the screen went blank while I was using it. I changed the batteries and looked at the wires that connect to the console everything looked good but still nothing. What do...
hi there, did you get your problem solved? I am having the same problem and are searching everywhere without a satisfactory answer. hope you can help out!
Oct 21, 2010 | Schwinn 430 Elliptical Trainer
During use, the speed goes to zero on the panel and then a couple minutes later, it shuts off....Schwinn 430 elliptical.
sounds like the sensor is loose or bad.I have the same schwinn 430 elliptical and my speed stayed at zero and after a couple minutes it would shut down.i called schwinn bowflex and they sent me a new sensor ($2.00)since my warranty expired and i installed it(not fun) and thats what fixed it. im back to working out.
Jul 10, 2010 | Schwinn 430 Elliptical Trainer
We have a Schwinn Elliptical trainer and the bar at the top part of the machine has completely come off. It is as if it has snapped at the base where it joins the bottom part of the machine. Is there any...
Call Nautilus @ 800-NAUTILUS (800-628-8458) if it is only the console mast and their is no more extensive damage to the lower frame and if the part is still available it might be worth your wild to repair the unit. If not junk the unit!!!
May 28, 2010 | Schwinn 430 Elliptical Trainer
Find repair service for schwinn treadmill
short of changing batteries ,if you got them, theres nothing you could do other then replace it, If your speed rpms and distance doesnt read its the speed sensor
Feb 03, 2009 | Schwinn 430 Elliptical Trainer
Need to replace the drive belt on my Schwinn 430 Elliptical
http://download.dfxi.com/supportdocs/SM/Schwinn/SCH_430_431_450_SM_RevC_web.pdf
Follow this link for step by step instructions. Note you will need a crank puller which you can purchase at most bike shops. remove both covers then crank weldment(discs).
Jan 19, 2009 | Schwinn 430 Elliptical Trainer
Schwinn 430 Elliptical Trainer Logo
2,215 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
