Question about Hoover AAA140 Front Load Washer
Hoover AAA 140
Can anyone helpmy machine is coming up error 3 near the end of the cycle please let me know thanks a lot
  • jackiedawson Aug 14, 2008
    hi i have error 2 come on at the start of any cycle ot is not filing up with water,have tried spin cycle and that works,just no water,
I have this problem too. Also i've had error code 5 come up as well. I think error code 3 is saying that pumping water out for so many minuites has failed. I've cleaned and run the pump out of the machine and everything works ok and there is no blockages. There still could be a problem when wired back in the machine. I have seen the pumped water coming out of the waste hose. Does anyone know if there is a sycro motor on the back of the controller or program selector that may be failing ? (ie: teeth worn off drive gear like you get on centrol heating valves).
Posted on Jul 03, 2008
I have a Hoover H160i that is coming up with E05 error. Any ideas?
Thank you. I ran a 2 and 3 wash (60 and 40 degree wash). It allowed me to put it onto a rinse/spin/cycle but it didn't allow the wash.
Nov 28, 2012 | Hoover H160I Front Load Washer
Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin,...
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Sep 15, 2009 | Washing Machines
Hoover AAA 160 Washer error code 4
PLEASE INSPECT DOOR BOOT (RUBBER DOOR GASKET) IF NOT CAN BE FILL VALVES NOT COMPLETELY TURNING ITSELF OFF ,,, IF ALL LOOKS GOOD REPL/ PRESSURE SWITCH
Nov 29, 2008 | Hoover AAA160 Front Load Washer
Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Nov 23, 2008 | Hoover AAA160 Front Load Washer
Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Apr 11, 2008 | Washing Machines
Error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Feb 03, 2008 | Hoover 24 in. HD97E Free-standing...
Hoover AAA 160 Error 3
If you are certain that all pipes are clear, then you may wish to check the pressure pot & pressure switch ( & small hose joining the two as this could be telling lies to the program unit. If the machine is emptying but the switch fails to read the level correctly, it can cause the same sort of error problem. Pressure pots can fill with the "grey soap gunk" and switches pressure are a reletively common fault also. Good luck
Jul 27, 2007 | Hoover AAA160 Front Load Washer
WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
the usual issues with this type of washer is the relay board located inside the top of the unit. as i remember mfgs make a nice unit but are not so good for sealing the electronics off from the rest of the unit. chances are some moisture is up in the relay or relay socket. easy access you will see several relays. pull and tag each as you do to avoid confusion. check for corrision build up on any part of this unit. this should help.. gl k
Jun 10, 2007 | Hoover AAA140 Front Load Washer
Hoover AAA140 Front Load Washer Logo
207 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
