Question about Fujitsu Office Equipment & Supplies
Fujitsu fi-5220c scanning error windows 7
Error scanning with windows 7
4 Suggested Answers
  • 16 Answers
SOURCE: Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Posted on Sep 16, 2009
SOURCE: Fujitsu fi-4120c scanner on Windows 7
sorry NO
Posted on Mar 09, 2010
TechSatya
  • 104 Answers
SOURCE: fujitsu scanner light bar will not return to
When you face such errors, please check if the Scanner panel displays-"E-0" and TWAIN displays- “The running system is abnormal. Please confirm the carrier lock has come off.”
The error is Carrier unit drive alarm. After power-on, carrier unit (FB) moves to home position, that is where the carrier unit locates when home position sensor is turned ON. If the home position sensor is not turned ON after the carrier unit has moved pre-defined steps, this error occurs.
Probable causes:
Defective sensor, motor, or carrier belt.
Also, please check the following:
1. Is there is any abnormal noise from FB motor when this error occurs?
2. Does any foreign object get inside drive unit or carrier unit?
3. Is CR belt tension loose? Loose belt should be tightened.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Posted on Jul 27, 2010
Error 2148285
What driver are you using no twain suggests that the driver is not twain compliant. You may need to update the driver with the correct operating system like windows (whatever it is) or is it MAC OS .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-series.html
Apr 21, 2014 | Fujitsu Fi-4120c2
Fi-5220 c driver for mac
www.kofax.com and search fo fi-5220c. There are some software there for the MAC.
Feb 06, 2014 | Fujitsu fi-5220C Flatbed Scanner
I need the software to fujitsu fi-4120c2 - I have windows 7
Hi kimberly...
fujitsu fi-4120C2 printer drivers can be found at driverupdate us (xp/vista/7/8).
It will take 2 mins from you to install...
after updating, go to word and try to print something
I hope I have helped you...
enjoy
Apr 06, 2012 | Fujitsu ScanPartner fi-4120C2 Path-Through...
FUJITSU Twain 32 - Code DS42019 Error pops up on screen whenever I try to use my scanner. I have restarted it many times. Any advice?
Here's what I've done. Maybe it's too late to help.
1) install the latest driver
2) restart
3) go to device manager
4) right-click on unknown device and click update driver
5) Select Let Me choose and select an imaging device
6) Click have disk and browse to c:\windows\fjmini and select fi4120c.
7) let it install the unsigned driver
8) You may have to restart after installing
9) Try opening your scanning software and then select the WIA driver for your scanner
I've installed many fujitsu scanners on windows 7 systems
Works perfectly.
Apr 21, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
Scanner not reading as clear
Is the glass clean, you may need to open the scanner and clean the inside of the glass if condensation has got inside
Aug 30, 2010 | Fujitsu fi-5220C Flatbed Scanner
Fujitsu scanner light bar will not return to
Probable causes:
Thanks & regards,
TechSatya
Mar 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Hi ocdaveymac
Fujitsu fi-4120c scanner drivers can be found at
driverupdate us .
enjoy
Mar 09, 2010 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi-4530C
Hi
Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
Open Questions:
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
