Question about Kodak EASYSHARE M763 Digital Camera
Memory card i cant get my memory card out of my kodak easyshare m763 digital camera
  • keefedebeef Jan 04, 2009
    you have to push the card in and then it will come out
You have to push the card in and then it will come out
Posted on Jan 04, 2009
Kodak troubleshooting
If the deleted pictures were on a memory card and you haven't done anything with the card since you deleted them, maybe.
Do a Google search for "data recovery software." Pick a program appropriate for your computer or operating system. Take the card from the camera and put it into a card reader attached to your computer. Cross your fingers and run the program.
Sep 01, 2014 | Kodak EASYSHARE M763 Digital Camera
IF IT COMES INTERNAL MEMORY FULL EVEN IF THE MEMORY CARD IS 2GB WHAT SHOULD WE DO
How to switch the camera over to saving pictures directly onto the SD card.
  1. Menu
  2. Cam settings
  3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 18, 2010 | Kodak EASYSHARE M763 Digital Camera
Camera wont turn on-batteries are OK
Here are the steps for M763 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak EASYSHARE M763 Digital Camera
My kodak m763 lens wont open. and when i turn on the camera it says kodak easyshare and it turn back of
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new cable.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EASYSHARE M763 Digital Camera
None of the functions are working on my camera and it keeps flickering
Try To used the camera without the memory card and remove and reinsert the battery., if the buttons or menus will not work call tech support of kodak Toll free 1 800 235 6325. It means the board of your camera ois defective
Nov 08, 2009 | Kodak EASYSHARE M763 Digital Camera
Won't turn on
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 08, 2009 | Kodak EASYSHARE M763 Digital Camera
Kodak EasyShare M763
I went ahead and looked this up for you. Kodak says you need a Li-Ion Rechargeable Digital Camera Battery KLIC-7001.
You had the right idea, but the wrong number. Hope this helps.
Aug 17, 2009 | Kodak EASYSHARE M763 Digital Camera
Macbook says file type "unrecognizable" from Kodak M763
It seems that your computer doesnt recognize jpeg files . Download or reinstall quicktime to fix the problem, you can get free download at www.apple.com
Mar 25, 2009 | Kodak EASYSHARE M763 Digital Camera
Kodak EASYSHARE M763 Digital Camera Logo
56 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
