Question about Frigidaire Washing Machines
I can only use delicate or lower settings. All others run for about 2 min. And then go to 3 min left in cycle
Can not change any temp nor spin selections on higher cycle selections no lights even light up
  • Hugh atkinson Nov 01, 2012
    Frigidaire affinity front load washer
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 01, 2012
3 Suggested Answers
  • 35 Answers
SOURCE: won't spin
As previously suggested, try cleaning out the drain system. See my solution at http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Posted on Mar 30, 2009
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune TL electronics problem
I’m not sure what machine model you have your in the FAV6800AW forum. I got Maytag CSV to send me a Control Board for my FAV6800AW. Had to do some arm twisting it is under warranty for 5 years. If you think your Control Board or console is under warranty give it a try. They wanted a Cert Svr Tech to diag the problem. I told them my neighbor was a Svr Tech (me) he had diag the problem and would install the part. They sent me the Control Board, it might be worth a try. I have a number spare parts not under warranty and ebay is my 1st choice, Second Choice . I use this for parts look up Sears Parts Direct.
What is your model type? It sounds like you have Service Manual for your machine and you are troubleshooting in the right direction. Do you have surge protection on the 120VAC outlet powering your machine. Good Luck Rich.
Posted on Jun 21, 2009
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
Only Power and door light comes on - no wash cycle selection
To start the door sensor is faulty, in any case you have more than one problem. which is make and model?
Mar 02, 2008 | Washing Machines
I just got done using the Santitary cycle, first time. I ran for 2 hrs. I take the blanket out.
The washer has not drained all the way. If you did not use HE detergent then the suds are causing this. If you did you HE then the filter is most likely full and the machine did not drain all the way. There is a way to check it and it is not easy. The back comes off. When you take the back off, on the left side is the pump and the filter.
Sep 07, 2015 | Frigidaire Affinity ATF7000E Front Load...
Stuck in spin cycle
The heating element maybe faulty,
or even the thermostat .
If one is not working,
and the temperature does not get to the required temp,
the washer reboots, and tries again,ect
Nov 19, 2013 | Washing Machines
Asko washer W6324. Ran two loads with no problems. These used the SANI setting (wish I could control the water temp by temp settings and not fabric descriptions). New load of delicates. I set it to woolen...
Try to press the start/stop button for at least 3 seconds. This should reset the started cycle, and you can make a new choice. If this dont help, it could be a faulty control board
Sep 29, 2013 | Asko Washing Machines
Auto coolant hot temp light comes on and temp gauge goes up more when idling at a light
If temp gauge is going into the red on a 3.4 engine it must be shut down or head damage can happen within minutes. I have a Monte Carlo that was overheating. I changed everything, thermostat, water pump, belt tensioner, radiator, all with no result. It would start out okay on a cold start but then I would come to a red light and the temp would creep up. Higher and higher until it neared the red zone. The heat would run cold. Most of the time, as soon as it was about to touch the red it would start to drop, the heat would blow hot again and all seemed okay but not for long. This would get worse and worse until the red hot light came on and I found myself on the side of the thruway. This problem is a blown head gasket. I had no other obvious signs, no white smoke from the exhaust, no oil in the antifreeze. I even changed the intake gaskets. Head gasket issues are common on the 3.4 liter engines.
Sep 09, 2012 | 2002 Chevrolet Impala
I have an Omega CW 675-A washing machine and I have just moved in but the owner did not leave an instruction booklet for the settings. Is this a free service? Can you help me? Paul
Hi
The particular model number is not listed in the list of manuals of omega washing machine.Please call the customer support for assistance.However given bellow are some settings of the washing machine,which is extracted from a website.Hope it helps:-
7 is warm wash delicates (warm cycles then it runs through the number 10 delicate cold cycle too)
10 is cold wash delicates
1 is the longest regular cycle
I normally wash with only the cold tap on, 3 for dirty washes, 4 for regular washes.
Soap goes in the middle slot
3 Buttons from left to right
left - in to spray rinse
middle - in to NOT spin dry
right - in for NOT boost heat (or maybe it has no booster and it is just in for cold wash - not sure)
when standing in front of it, reaching over the back, the left connector is cold and the right connector is for hot water.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 09, 2011 | Washing Machines
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Washing Machines Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
