Question about Camping, Backpacking & Hiking
Rayovac 360 sportsman lantern wont work
Bulbs and batteries good and properly placed
    New Friend:
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Posted on Dec 03, 2012
How do D batteries install into a Rayovac camping lantern?
If there is no access panel on the bottom for the batteries then the base itself must unscrew to give you access. I'm sure that will work for you.
Oct 04, 2014 | Rayovac Krypton Lantern 4 D SP4D Kb
Rayovac sportsman 360 lantern
It tells you on the top of the lantern if it is the 6 volt type - you unscrew the large knob, and the base will come off when it is unscrewed completely. To change the florescent bulbs, you unscrew the small knob.
Sep 06, 2013 | Camping, Backpacking & Hiking
I have a 6-7 year old Rayovac Workhorse Lantern- I bought 2 new 6 volt batteries and 2 new tube bulbs for it but it still doesn't work. How and where should I take it to be checked?
The odds that both bulbs went out at the same time is pretty low, actually. It's more likely that there's corrosion in the on-off switch or that an internal wire may have come loose. It's also possible--and I've made this mistake myself--that one of the 6-volt batteries has been put in backwards so that the polarity is not properly aligned for both batteries.
With all that said, here are a few simple tests you can do.
1. Check the batteries. If you have a battery tester, are both batteries good? If so, check they are properly installed and making good contact with their terminals.
2. Pull the bulbs out and use a voltmeter to check that you have voltage going to each bulb tube. This basically means switching the light on and touching each of the terminals where the bulb(s) would clip in. You should see a strong voltage reading on one or both tubes-I believe that this light is designed to keep working, even if one of the bulbs is burned out.
3. If you don't get a reading from the bulb terminals, the on-off switch or wiring leading to is is the prime suspect. You may have to disassemble the light housing to get into that, which may not be particularly easy. At this point, you might want to call Rayovac customer service and see what they might do for you under their alleged lifetime warranty for flashlights. You may be able to send it in (holding onto the bulbs for yourself) and get a free replacement.
Nov 21, 2012 | Camping, Backpacking & Hiking
Installing the batteries in this lantern
Flip it upside down. some have a threaded cap you untwist off, and some have a screw you remove.
Nov 14, 2012 | Rayovac Krypton Lantern 4 D SP4D Kb
Purchased the Disney Tangled Glimmer and Glow Lantern. Trying to replace the 3 AAA batteries that it came with - but doesn't work w/ others (tried 2 different brands of batteries - both new) won't...
I had the same problem initially with this toy. I tried to replace the factory batteries with regular AAA alkaline batteries with no luck. I went to a specialty battery shop to try to find the carbon zinc replacement batteries also with no luck. When I got home I remembered that I had a basket full of rechargeable batteries of varying sizes so I thought that I would sift through them to see what I had. I found three of the Rayovac 15 minute rechargeable NiMH 2000 m A h AAA batteries and I charged them up just to see if they would work in the toy- THEY DID!!! I would imagine that any battery like this would work whether it was rechargeable or not- and they're probably a little bit cheaper too. I hope you have good luck making your lanterns sing and glow again too!
May 18, 2011 | Creative Design Disney Tangled Glimmer n...
I tried to replace the demo batteries and now I cannot get the lantern to work
Dec 27, 2010 | Creative Design Disney Tangled Glimmer n...
How do you get the battery case open?
hold the battery pack in you hands with the system facing away from you. Holding the unit firmly, grasp the right hand end and twist it toward you. The batteries should be placed with the two outside positive ends up and the middle one with the negative end up. Place the end back on the battery case with the top of the cap slightly toward you; push in firmly and twist it back into alignment with battery case.
Nov 24, 2010 | Rayovac Sportsman Led Headlight
Coleman rechargeable lantern: Charged overnight - not working, replaced bulbs - not working. What could it be:
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Jul 20, 2010 | Coleman Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
709 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
