Westinghouse 32" tv. Cannot get more than 22
  • 127 Answers
Go to menu and select Tuner, then cable, go to search chanels wait and the television will search for all active channels automaticly.
Posted on Nov 01, 2012
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
dave1645
  • 834 Answers
SOURCE: Westinghouse TV no picture just sound. 32
one or 2 caps in the power supply they will be domed from venting
Posted on Sep 16, 2009
dave1645
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
SOURCE: westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
Posted on Mar 23, 2010
budmrtn
  • 11361 Answers
SOURCE: WESTINGHOUSE TV 32 IN LCD TURNS ON FINE, SECONDS
Check for cold soder joint in the 24vdc power supply section, especially on C310.
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
The problem can also be the backlight inverter baord.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 07, 2010
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
How do i get cable tv on my westinghouse tv
Go to the menu look for the input settings make sure it is set for cable not air. There might be a input button on the side of tv or on remote that will let you select which input to use. It will have to be set on cable thin scan for channels.
Aug 08, 2017 | Westinghouse 32-inch Led-lcd Tv - 720p...
Watching tv and all of a sudden it starts flipping through the channels and won't stop
If you have _no antenna_, make sure the menu (for channels) is set to either ''cable'' or ''satellite''. The TV needs to _know_ there are no ''antenna'' channels to scan for.
If the above doesn't work, try unplugging for a _full_ 24 hours. Then plug in, turn it on, go directly into ''menu'' and do like I stated above.
Note: ''Capacitors'' can ''hold memory'' for a long time. That is why ''unplug for full 24 hrs.''
May 18, 2015 | Westinghouse 32 Flat Screen 720p Hd Led...
How to reset my westinghouse flat screen tv
if you are using an antenna for digital channels,it will search for 100 to 125 channels,if searching for the old analog channels,it only searches for 75 channels,but,you will not receive them,they are gone now,if you have a cable box,then you only need channel 3 or 4,
May 18, 2015 | Westinghouse SK-32H540S 32 in. LCD TV
Lost remote want to use a univerisal remote but tv say front panel lock How do I unlock it? 32 in westinghouse
On the TV itself, MENU, SET-UP, INPUT, VIDEO then go to Channel lock and de-select it.
Hope this helps. If you post a model number, I can probably get you a manual.
Good luck, R.J.
May 13, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Unable to program cable channels on westinghouse lcd tv
There is some system reset to set the tv back to default settings. Also some boxes are picky and want the tv to be on chanel3 or 4 for the scan.
May 31, 2009 | Westinghouse 32" Flat Panel LCD HDTV
How do I digitally tune my westinghouse TV SK32H24OS. Lost manua
The easiest way might be to unplug the power from the set for several minutes, plug it back in and then run through the setup procedure. You are specifically looking for the channel auto scan function.
Feb 25, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Blank screen no access
try setting up the tv using the default setting
make sure that the tv searches and installs al of the channels
Lou Margo
Allied electronics
Jul 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
