Question about Scotsman Refrigerators
Scotsman ice maker mod afe400a-1a is making ice but ice has some dark spots in it. Looks to be shavings of brass. Would this be the bearings in the auger that pushes out the ice going bad?
    Novelist:
  • 187 Answers
Yes.
Posted on Oct 01, 2014
3 Suggested Answers
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
Ironfist109
  • 3018 Answers
SOURCE: the model for Scotsman ice maker is AFE400A-1B and
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Mar 15, 2011
Scotsman ice machine slow water fill
Check to see if there is a water filter inline if so then change it. If not then check where the supply water line is hooked up to the machine pull line off and turn water on to make sure you have good water pressure. if you have good pressure then pull the water inlet valve and take it apart to make sure it is not stopped up with trash and that is it.
Mar 12, 2015 | Scotsman CU1526SA-1A 150 Lb Self-Contained...
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
Model # CU1526MA-1A Sounds as if solenoid is kicking in, water runs, but makes no ice
You can go to a dealer that sales this machine and they can order you a manual.
Mar 10, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman cme456as-1a
Google CME456as-1a service manual you can find PDF to down load.
Jun 14, 2012 | Scotsman Cooled Modular Contour Cuber Air...
The Cube Grid is loose on my Scotsman SCE170A-1A, What is the best way to repair?
Sorry cant be repaired The evaporator plate will need to be replaced with the plates loose like that it will cause the ice to hang up and not drop when in harvest. depending on how old the unit is it would be more affordable to replace the machine. coil cost 1800.00 labor 600.00, freon, dryer, 300.00.
Jun 13, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The model for Scotsman ice maker is AFE400A-1B and it stop making ice. Can you help me diagnosis?
Mar 15, 2011 | Scotsman Ice Maker WBin Flake Style water...
I have a Scotsman AFE400A-1H flaked ice maker, that has started to produce "dirty ice". I have read that the unit has a in-line filter, how do I access the filter, to clean or replace it? ...
Shut it down and have a professional look at it immediately. I do not know of an inline filter and the knocking noise indicates something really bad happening inside of the evaporator / auger housing.
Nov 24, 2010 | Scotsman 22 Wide Ice Maker Bin 242 lbs
Refrigerators Logo
118 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
