Question about Westinghouse Washing Machines
I have a 711 front loarder it will do a quick 30 cycle but if i put it on a 1/55 cycle it comes up with a IE fault
    Top Expert:
  • Westinghouse Master
  • 9,472 Answers
"IE"
- Water level sensor error
Water sensor fails to send signal for longer than 5 seconds.
Press POWER button. No other buttons work:
Check wiring harness
Check pressure sensor switch
Check circuit board
Posted on Nov 01, 2012
What to check if no power appear nor light when pushing the power button on after pluging in the ac power
Just looking for burns is not enough. You will have to put a meter to every output and make sure it is supplying the proper voltage.
Apr 30, 2014 | Acer AC 711 17" CRT Monitor
Error IE when washing on quick 30
Inlet water not coming in check tap valve at inlet valve there is one strainer clean otherwise inlet valve gone.
Feb 11, 2014 | LG WM2487H Front Load Washer
LG washer not draining
IF ITS FRONT LOARDER DEFINEETLY PROBLEM WITH DRAIN PUMP...
Jan 26, 2014 | Washing Machines
Stops mid cycle and clears
It could be the heating element is at fault not heating to the selected temperature 95 degrees 40, 30,and so on, if one of these fail to work then the washer will not continue
also maybe the thermostat may be at fault, causing the same error
Nov 18, 2013 | Zanussi ZWF1020 Front Load Washer
Is $711 for front struts replacement, trans fluid flush, 4cyl tune a good price?
that comes out to a labor charge of$ 83.25 per hour. No that's not right it's a BARGAIN. The going rate locally is $90..00 and up per hour
Nov 21, 2011 | 2006 Toyota Matrix
Takes ages to get through wash cycle
You should have a quick wash on your unit. By using a concentrated washing powder you can do your washing on quick wash mode which most manufacturers set to approximate 30 minutes. In a front loader most clothes can be washed on a quick cycle. Because of the way they wash.
Jul 26, 2011 | Washing Machines
LUMINA WM3011. Front Loader. I put in a load of washing, pushed start (quick cycle) then bad decision quickly opened door! Now cycle won't finish completely. Bring up error message of EO3 - don't know...
OK, I can't find anything on this machine for free. Do you have a user manual?
If not, try this. Unplug the machine, wait 30 seconds, plug the machine back in. At this point, I would think the machine would go back to a default setting. You should then be able to try to restart the cycle.
Good Luck, let me know how it goes.
Gary
Jan 15, 2011 | Washing Machines
Hot point f-08 fault code
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Thanks.
May 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
WMA10 abridged programme cycle
is the drum going round at all if not then most likely your carbon brushes which puts power to the motor there is 2 either side of the motor you will need some bent nosed pliers to take them out must have at least 8ml of carbon on them
Sep 26, 2006 | Hotpoint First Edition WMA12 Front Load...
Washing Machines Logo
48 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
