Question about Conair HCR1350Y Clock Radio
Antennas on vehicle body missing
Where can the antennas be purchased?
    New Friend:
I have same one from garage sale and also antennas is missed.
That antennas at top of H3 is fake antennas so I add the plastic car model (leftover parts) The real radio antenna is inside of battery door under H3. Mine is remote control and power adapter are missed from garage sale . SAD !
Posted on Sep 26, 2014
The problem is: The antenna(s) on the body of the radio are missing. Would like to know where they can be purchased. Not a rocket science question. Any assistance would be appreciated.
Posted on Jan 04, 2009
  • Rusty Crow
    Rusty Crow Sep 26, 2014
    The antenna at top of body is fake antenna . Same here but I just add with plastic model left over from other old car model. The real radio antena is under body and find in battery door.
I have a TV and no cable. how can I watch TV.
You could purchase an antenna and get the local stations
Dec 31, 2017 | Televison & Video
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
I have 2 cobras 29 radio always worked good till recently. Have a rk56 mic I can hear but can't talk. Mic keys up but they hear nothing bought a new 29 chrome digital read out and a new mic just a wood...
fiberglass,no ground plane. Did you use the meters on the radios to match your antennas or a seperate external might have to run your own coax and hook up a mirror mount bracket and put your favorite antennas on them then match them and ground them to the chassis use common sense to show you what to do next and you should be getting out great. Sometimes people change the antennas on those trucks with built in antennas and don't realize that the coax has just fallen out of site into the body somewhere. thats why I said install your own.
Aug 26, 2014 | Radio Communications
Why wont my digital tv work now?
External antenna is not adequate. Need more and bigger antennas for digital TVs. Also, several BAD problems with digital TVs - including weaker signal, picky signal, inability to use in a moving vehicle (kids can no longer watch TV while moving from place to place). More expensive receivers, not normally useable in remote places (like you could with analogue).
Rarely, two or 3 antennas on a vehicle will allow for some reception in a slow-moving vehicle - otherwise, portable digital TVs are useless.
Oct 20, 2009 | Jensen VM9510 Car DVD Player
I replaced a standard antenna with an electric antenna in a 199 Ford Contour. All the mounting brackets were there, but the wiring harness was not. I need to know how to wire the electric antenna (wire...
If it is a three wire electric antenna. The Ground wire is usually black. To find out which is the trigger wire simply connect the black wire to ground and then power one of the other wires, if you here the clicking of the relay you know this one is the trigger wire and the other wire is the power wire.
Sep 04, 2009 | Car Audio & Video
Missing wifi antenna
You cannot actually get a replacement as such, however you can get antennas called Range Boosters, Extenders from, say Radio Shack, or the like.They screw on.
Oct 19, 2008 | Acer Aspire L100 PC Desktop
Antennas Uniden Bearcat BC148XLT
Height and placement of the antenna determines range. Also, check to see you have the antenna perpendicular to the ground (straight up), and place the antenna where it has 19" clear around it. (not up against a wall or other obstruction)
Placing the existing antenna higher, or replacing it with an external antenna would give you more range. A simple test before purchasing a new connector, coax and antenna for the scanner, would be to place the scanner where you think you would place an antenna and see if it gives you the range you desire.
External antennas are available from most any radio shop. (They would need to know what type of connector you need to connect the coax to the back of the unit.)
Sep 09, 2008 | Radio Communications
Antenna for my HDTV
Special HD or Digital antennas are not required to receive digital stations. A good VHF/UHF antenna should work. Try an amplified antenna for the best reception. Most antennas have a coax type connector which should connect to the ant. in jack on the back of your DirectTV box or to your tv depending how the box is connected to your tv.
Jun 25, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Thanks for the assistance
Hi again richos,
The outside area of the antenna plug would definitely touch the body of the CD/Tuner as it is the ground where the shielding of the cable is soldered to. I was referring to the central point where the active wire is soldered to and is connected to the exposed antenna element.
Another possibility to consider is the orientation/location of the vehicle/antenna (though unlikely).
As to the FM, it would still work (even if shorted) since it operates on MHz (unlike AM in KHz). Some antennas for FM (exclusively) even have a balun (coil) matching which is shorted when tested for continuity.
Have you tried the insulated wire?
May 25, 2008 | Pioneer DEH-1000 CD Changer
Will antenna help?
What is your car brand & model?
I ask, because some vehicles use a thinfilm windshield heater for defrosting/de-icing. This file is conductive, and will act as a shield to the RF microwave signals that GPS operates on. Consulting the owners manual, or the car dealer could help determine if this is your case.
Please try the unit outside the vehicle (in the same location as you have troubles) and see if the issue resolves itself. If so, then yes, using an external antenna can resolve the issue, but it will need to be located in a place not covered by that same problem.
All GARMIN external antennas are waterproof and have a very thin cable, so it could be located outside the vehicle. Alternatively, a side-window mount for the antenna could be used, if that's a viable solution in your application.
The "less-expensive" antennas mentioned can work, most will, but you may not get the optimal performance as one designed specifically for the GARMIN units. Personally, I've used an afermarket one and had good results, but the GARMIN ones always seem better.
Mar 24, 2008 | Garmin StreetPilot c340 GPS Receiver
Conair HCR1350Y Clock Radio Logo
160 people viewed this question
Top Conair Audio Players & Recorders Experts
Are you a Conair Audio Player and Recorder Expert? Answer questions, earn points and help others
