Question about Procom Heating & Cooling
Is it suppose to come off and on over and over
After the blower its starts up again
Yes, heaters will shut off after a number of time and then start up again to maintain the correct temperature.
Posted on Nov 01, 2012
No heat in dodge stratus 2002.. when my car idles I get heat once I start moving I get no heat. What could be the problem? I just got it fixed cause the blower went out and I dont want to have to pay...
It appears to me that your engine needs a new thermostat. It must be stuck open. It's supposed to stay mostly closed until your engine coolant temperature gets up to something like 190 degrees F... then it's supposed to keep it up to that temperature stopping or going...
Mar 17, 2014 | Cars & Trucks
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
I have a Goodman Furnace that doesn't turn on. If I spin the blower it will run, blower just buzzes and still buzzes while running. It shuts itself off after twenty minutes. I can resets it and spin the...
First I would suggest that you replace the start capacitor on your blower motor but if it is running for awhile that makes me wonder if the thermal overload is shutting your motor off. You can replace the start capacitor and then if it starts as it's supposed to and then shuts off you'll know the motor needs replaced also. I hope this helps you . THanks
Nov 30, 2010 | Goodman CLQ24AR42 Air Conditioner
My 130bt blower stops reving after several minuets. Will start but not rev after running fine for 5-7 minuets?
Hi and welcome to FixYa. I am Kelly. The next time it does this... loosen the gas cap a lot momentarily for about 10 seconds then tghten it and attempt a restart. If if starts right away again the gas cap is bad. It is supposed to breathe via a rubber seal in the cap. There are 5 parts in the cap. If it can not breathe the gas tank goes into a vacuum as fuel drains and you will experience fuel starvation.
Also check inside the fuel tank for debris.
See this link http://www.jackssmallengines.com/help.cfm#Home
Click on
Husqvarna Power Equipment
Blowers
130BT (I used the 2001 - 2007) There is also a 2008-2010 choice
and then click on Fuel tank a.s.s.y
I suspect the problem is either going to the the fuel cap or the fuel filter.
Thanks for choosing FixYa,
Kelly
Nov 10, 2010 | Husqvarna 295cc Back Pack Blower HVH 130BT
Gmp075-3 furnace burners ingnite then shut down
ok check yoour air flow sounds like its tripping out on high temp
the blower comes on too cool the eqipment
you may need to clean the coils on top of the bloower
Oct 05, 2009 | Ruud Matching Split Air Conditioner
Blower Motor Stopped Working Again
here is a piture of the seed control resistor module, it goes into the air duct near the blower motor.
Apr 28, 2009 | 1996 Chevrolet Blazer
Toyostove laser 55
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
41 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
