Question about Dirt Devil M082123 Power Pak Handheld Vacuum
Dirt devil hand held vac (power reach) brush not spinning
I've taken it apart, checked the hose to make sure it's in place & locked, but the brush just quit spinning. any ideas?
  • Anonymous Jan 31, 2009
    The brush (or beater bar) on my unit will spin but it is very weak and only works occasionally. As soon as the unit comes into contact with the floor, the brush stops spinning. It really is a recently purchased item and we clean it after every use. To have this problem for no apparent reason is frustrating. If anyone can offer any advice, please do.
    Thanks.
5 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Posted on Mar 06, 2009
SOURCE: DIRT DEVIL CLOGGING IN THE HOSE
What is the solution to this problem ?
Posted on Sep 19, 2008
  • 10 Answers
SOURCE: Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
Posted on May 26, 2009
SOURCE: need instruction on dirt devil mop vac
I found very basic direction on eHow
Posted on Mar 20, 2010
  • 731 Answers
SOURCE: Dirt Devil 086905 has suction
Need to take the head apatr as if you were replacing a belt. Look for the clog... it's there
Posted on Apr 01, 2011
Henry hoover airo brush not working
yes, it probably is stretched.
Jan 07, 2014 | Vacuums
Why would my dyson dc 17 brush motor be extremely loud, but sound normal when brush is not spinning?
could be the bearings on the end of brushbar need replacing,or it may be the clutch needs setting , lower the handle down to the floor then up again do this about three time to reset clutch....
Nov 13, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Have a power brush and cannot get the brush out to clean. I've taken off the main cover, but the brush is held in by a bracket. I can't take off the main cover as I don't have the right kind of...
I have a Miele STB-205-3 Turbobrush. After opening the brush cover using a quarter, I use a T-7 torx screw driver (shaped like star of David) to remove the main cover that is held by 4 screws.
There are 2 more screws holding the fan housing. After unscrewing them, you can take the whole thing apart and clean it. Make sure you clean all rotating parts as they collect a lot of hair, dust, etc,
Sep 13, 2011 | Miele S251i Plus Bagged Canister Vacuum
The brushes won't spin. I have removed and
On mine there is an air turbine that powers the brushes. There is a red screen that you squeeze and pull out to clean. Perhaps yours is clogged. If the screen is clear, perhaps the turbine has something binding it to keep it from turning. I hope this gets you on the path to repair your problem.
Oct 30, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Windtunnel quits picking up
clean or replace the main filter. this filter is non washable. the best way to clean is to use a paint brush or compressed air. hope this helps
Jul 25, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
Dyson Animal with no suction from floor brushes
Check the canister seal for dirt or gaps. This is normally where the vacuum leak is.
May 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Re - Assemble
heres the manual for your vacuum this should help you out. let me know if it doesnt
CLICK HERE
Jun 15, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes do not spin on my steam vac
We were having the same problem with the brushes not spinning.
How I fixed it:
I Removed the brush assembly by gently pulling on both sides of the assembly. I took a wide slotted screwdriver and inserted it into the slot (hole) that turns the brushes. At first it did not want to move. I GENTLY applied pressure by turning the screwdriver to get the gear to move and it began to move freely. I spun the gear a number of times using the screwdriver to make sure it was moving freely.
I reinstalled the brush assembly by aligning the gear that slides into the slot and gently pushing the clips back into place using equal pressure on both sides.
I plugged in the machine and the brushes now spin!
Good luck to everyone out there!
Jan 21, 2008 | Hoover F7222-900 SteamVac Upright Vacuum
Dyson DC07 loss of suction
Hi.
Check brush roller is spinning when vacuuming.
Check short clear hose under machine for rips & blockages.
http://dysonmanuals.llc.nu/
Chris..
Jan 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vaccum has no suction
Need a new belt -- you might have suction but you need the brush to spin (hard to help without make or model, upright or canister)
Oct 17, 2007 | Kenmore 25614 / 25615 Progressive Bagged...
Dirt Devil M082123 Power Pak Handheld Vacuum Logo
219 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
