Question about Mitsubishi Televison & Video
My television blinks an orange light then turns off
We just replaced the lamp 6 days ago. It has been fine since the lamp replacement, now it blinks orange and turns off
  • 127 Answers
Chec for ground, or a short circuit.Same Lamp?
Posted on Nov 01, 2012
SOURCE: Lamp Replacement Problems for Hitachi 50V500A
I'll tell you what I tran into and how it got resolved...
I experienced the same problem , with the blinking light...
Purchased a replacement lamp..
It didn't work(After market Universal supposably)..
Well..Come to find out.The Replacement lamp's housing looks similar, but the connecters that come out the back of the housing weren't quite long enough to trigger the microbe that activates the lamp in the Television.
Luckily I had the original lamp and it's housing that came with the television..
Took the bulb out of the new replacement lamp
Placed it in the original housing , and BINGO..It worked and is still working...
Posted on Jan 16, 2008
Techvisitor
  • 63 Answers
SOURCE: tv doesnt turn on after replacing lamp??
Just took a look at the manual.
This information is in the troubleshooting section of appendix H in the owners manual.
12. Lamp indicator light is a flashing yellow. Lamp cover door is open or lamp cartridge is not secure. See AppendixH for lamp replacement information.
Appendix H is a bunch of graphics. that you'll need to see to understand. i can't paste it all here.
Posted on Oct 31, 2008
tvtek
  • 1284 Answers
SOURCE: Replacement Lamp Hitachi 50V500
It must be a red light flashing as the 50V500 has no green lights on it. Make sure that when you place the lamp cover back on that it is activting the micro switch behind it. Otherwise the set will assume the door is open and won't ignite the lamp. Otherwise the ballast could be the issue.
Posted on Feb 02, 2007
  • 50 Answers
SOURCE: lamp light
Check the lamp switch that is located inside the door. Place the lamp in, and stick a flathead screwdriver in the slot (just make sure it moves) hold it there, and turn on the Tv. If that doesn't work check the new lamp, is it a generic lamp, if so they dont always work. If you still have your old orig lamp, take the old lamp out of that housing, and out the new lamp in the old housing. This should fix the problem.
Posted on Feb 09, 2008
eoddeputy1
  • 4 Answers
SOURCE: sony KDFE60A20 TV turns off and on with Red light blinking 5 times
Same problem here. 5 blinks is video related. I've been told to clean the screen by the lamp, as they could be clogged and causing it to over heat. Going to give thet a try first. I'll post what happens...
Posted on Oct 13, 2008
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52327 TV won't consistently turn on, new lamp
the problem is in the power supply circuit
capacitor may be or so the click mean theres cap are leakink or get dry that why is so long to power on.
hope that give you a idea.
May 05, 2010 | Televison & Video
I just replace the bulb in my JVC HD-52Z575 everything was fine for about 10 days. Now when I turn the TV on it works for about 30 to 45 min before it shuts off, the fan kicks in, and the LED power light...
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
Jan 25, 2010 | JVC HD-52Z575 52" Rear Projection...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
Tv not working after lamp replacement
CK Fan if it is going bad set will shut down.
Feb 06, 2009 | Televison & Video
Open Questions:
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
