Question about Carrier 38CKC036 Air Conditioner
Cleaning electronic air filter
I just bought a foreclosed home with a Carrier Weathermaker 9600 furnace & an electronic air filter and need to know how to check and clean the air filter. I think I cleaned it, but since there was only a tiny amount of dust, am worried I was looking at the wrong thing. Where do I get a manual on this?
Rebecca
  • Carol
    Carol Jan 30, 2014
    Rebecca, for my own interest - does the Carrier electronic air filter seem to clear the air?
  • 61 Answers
What brand and model is the air cleaner?
Often you can find the mfg. website and download the .pdf file of the manuals.
The air cleaner will be located on the return air duct of the furnace and should have a nameplate and a model# somewhere.
Some use disposable filters and some need to be cleaned with dish detergent and can be very fragile. Hope this helps.
Matt
Posted on Jan 04, 2009
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier weathermaker 8000
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
Carrier weathermaker 9200 furnace air filter placement
air filter for your model can be found on amazon, click here and take a look: 20x25x5 Electrostatic Washable Furnace and Ac Filter 19 3 4 24 3 8 4 3 8. I hope this was helpful. Cheers
Feb 17, 2013 | Heating & Cooling
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Furnace overload limit switch
Here is the service manual with wiring diagram.
Dec 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker won't stay running
Is this a gas furnace if so is it high efficient if so is there an led light on the furnace blinking a code usually seen through a window at the furnace. is the thermostat battery operated if so is it a new battery and are the aif filters new. These would be my first steps to check hope this helps
Dec 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
205 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
