How to connecta gva 100 set top box to a teac model LCDV2655HD
How to connect to a LCD TV
jerryg50
  • 1667 Answers
SOURCE: no audio
I will try to explain this clearly.
Make sure that there is sound leaving from the connections on the top box.
Check that the audio cables are connected to the associated audio input for the video at the rear of the set. Make sure that there are no other shared inputs for the same input. With shared inputs, only one can be the default reference for input.
Check the menus in both the top box and the TV set to make sure that all setups are correctly done.
Jerry G.
Posted on Apr 14, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
driveallnigh
  • 89 Answers
SOURCE: I have a Samsung LCD HDMI 37inch TV series 5 do I need a set top box
No set top box required. Your TV has the latest technology. If so desired you could subscribe to a cable or satellite network and you will receive a box that will pick up all channels. HD channels are usually extra. As far as picking up "digital" broadcasting, no worries because your TV is already digital capable.
Posted on Apr 16, 2009
  • 280 Answers
SOURCE: remote for GVA LCD television
Try this site
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=lgdvt418&uuid=12454368371400
Posted on Jun 19, 2009
SOURCE: my GVA LCD flat screen TV switches itself off as
My flat screen will not turn on the green light flashes for a while then stops
Posted on Mar 03, 2010
How do I set up a universal remote to use with a tv?
The last universal remote I got had a list of numbers to input for different items. This was a little booklet and had lots of different items including tv's, blu ray players and dvd's. You need to look at list for your item and input that code to the remote. Hope this helps
Jul 15, 2016 | Universal Televison & Video
I have a teac LCD TV/DVD combo model LCDV1955 HD made in December 2008 and I cannot get a audiosonic universal remote control model JLR-6002 to work
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dec 02, 2015 | Universal Remote Control Televison & Video
Urc-l969 need all possible codes for teac lcd tv
0387,0386,0389,0338 are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 07, 2013 | Televison & Video
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
Need installation instructions for GVA 100 set top box
Just bought one of these cheap.
Very basic just plug in and it sets itself up to some degree.
- make sure tv is on appropriate AV channel as you'll need the on screen menu to set it up initially using the remote control.
- then set the unit to scan for the tv channels, took about 10 minutes for me.
- NOTE ... there is no power on/off switch. Plug the cord into the 240v outlet and unit comes straight on. You can't turn it off except by switching offf at power point. Or using the standby button on the remote.
- NOTE ... there is also no display on the unit. So yoy have no channel display on the unit. It is all done on the tv screen.
But it does have quite a good EPG and menu guide.
For the price, can't complain.
Jun 04, 2011 | Televison & Video
Need code to use in replacement urc for gva television
Hi, not familiar with this brand of television set but try all the codes on the programming sheet - you have nothing to lose
Mar 19, 2010 | One For All URC-3415 Remote Control
I have a digital set top box model teac dv-b800.this unit now has a flashing c-100 code has soon has you power same up and nothing else.Can you tell me the problem.
appears to be a known issue with your model of set top box and teac is aware of the issue, but will only repair for free if you are within your 12 month warranty period, if you are outside warranty, consider repairs as they are approx 60.00 and the fix appears to resolve the issue.
Cheers!
Feb 14, 2010 | Audio Players & Recorders
We cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Aug 24, 2009 | Televison & Video
Connet Hd set top box
May 31, 2009
Born to Race,
I have just bought a TEAC HBD841 which was on discounted sale at a local Electrical Store
Besides not being able to figure out how to connect the device to my elderly TV because the inadequate instruction booklet that is written in a language an Electrical Engineer would have difficulty understanding - does not explain which plugs go where, (try plugging a three plug lead into a 2 plug TV) but since then I have found out that the HDB841 has been withdrawn from sale and is no longer available.
No wonder it was cheap!
I suggest you get rid of it - quick
GB
Apr 20, 2009 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
