Question about Onkyo TX-8222 Receiver
No volume on onkyo tx-8222 receiver - Onkyo TX-8222 Receiver
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
hi-fi
  • 25 Answers
SOURCE: My Onkyo Receiver TX 601 is turning itself off
Adjust bass control to half position then feed loud signal,if it shut off adjust the bass contol to zero position,if it shut off again the defect is in the over load protection circuit it is already sensetive to loud signal.you may call the nearest audio amplifier technician on you.
Hope it may help you,
Posted on Dec 29, 2008
  • 14 Answers
SOURCE: Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Posted on Mar 05, 2009
marsrover
  • 682 Answers
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Posted on Apr 09, 2009
  • 4234 Answers
SOURCE: i have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Posted on Nov 04, 2009
I plug in the receiver and nothing happens; no light indicaters, no sound
Some commonlpace questions, ok, you don't need an expert for that:
Did you try another electric outlet?
Did you check plug, cable and connections to your receiver?
Did you try pressing on - off several times?
Sep 09, 2015 | Onkyo TX-8222 Receiver
How to hook up teac eqa-10mk2 to receiver onkyo tx-8222
Hi Daniel you can connect your Eq to the Tape2 input/output, if you need further assistance please give our Product Support Team a call at 800-229-1687 they are available 24/7, Thanks, JT
Apr 25, 2015 | Onkyo Audio Players & Recorders
Replacement Volume Knob Onkyo TX-5811
Maybe the cheapest and the best way to get the knob is to check ebay and buy the hole receiver for parts or check the link below. :) hope it helps
https://www.partstore.com/OpenSearch/Model/Onkyo+Corporation/Onkyo.aspx
Jan 29, 2014 | Onkyo Audio Players & Recorders
I have just bought a new Onkyo TX-NR808 and set it up over the week end with new 'accusound' surround sound speakers. Have bi-amp the front speakers. I don't think I am getting very good sound out of it?...
Depending on the amplifier, it might not provide enough power (in Watts) to the speakers. If the speakers require more power, it won't be as loud.
Mar 06, 2011 | Onkyo TX-8222 Receiver
My onkyo tx-8222 suddenly stopped amplifying on both speakers and headphones. I can hear music faintly with the volume at max (just the pre-amp?). Time for a new amp?
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Feb 21, 2011 | Onkyo TX-8222 Receiver
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo TX-SR806 Receiver
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
Onkyo tx 906 amp
1) I bought the same Onkyo model from goodwill a couple years ago and it had the same problem. The solution is simple: Get yourself some Deoxit D5. This is a spray that will clean out all the oxidation in the volume pot. To do this you'll need to remove the cover of the receiver. Deoxit can be bought at guitar shops, or if you know a musician they might be willing to do it for you.
2) User manual is available for download, for free. Google "Onkyo tx-906 receiver manual".
Mar 17, 2009 | Onkyo TX-DS575 Receiver
Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
May 21, 2008 | Onkyo TX-SR605 Receiver
Graphic equalizer
In general all equalizers, being designed to be in a Tape Monitor loop, have the option to Equalize either the Source or the Tape or nothing. Check for that control and toggle it. My old ADC SS-525X has pushbuttons whose settings (Tape/Source) are not easily determined. I always have to play around with it to know which is selected.
I'm betting your EQ is processing the program that would head out to an attached tape deck.
Nov 14, 2007 | Onkyo TX-8222 Receiver
Onkyo TX-8222 Receiver Logo
29 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
