Question about Whirlpool Duet 6.7 cu. ft. Electric Dryer
I have a whirlpool duet dryer 6.7 cu ft. Electric dryer and it is not drying. The vent is clean, but the front has said PF a few times, it takes 2 or more cycles to fully dry a large load. What do I do next if I cleaned out all the lint/vent hose etc. Thank you, Lindsey
  • Lindsey keller Nov 02, 2012
    Ok, it is a WED9250WRO. Once again, the hose has been fully cleaned. The digital numbers that show how much time is left keeps reading PF. Not every time. When this appears it automatically shuts off. The clothes are not dry at all and it will start right back up. I think it means power failure??? There is no lack of power. Our power went out months ago when we had the huge storm in June. Would it need reset somehow?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number?
Posted on Nov 01, 2012
huuum
  • 750 Answers
SOURCE: Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Posted on Feb 01, 2009
  • 583 Answers
SOURCE: whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Posted on Mar 03, 2009
  • 66 Answers
SOURCE: Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Posted on Dec 12, 2009
SOURCE: i have cleaned vents ducting and still have drying
go to the end of the vent and actually feel if there is air coming out if not you either missed a plugged vent or the blower is not working. deep inside the lint trap is a hard spot to find it plugged als can you hear the drum spinning
Posted on Oct 30, 2010
  • 4 Answers
SOURCE: Why does it take two
Turn the dryer on high heat and go outside the house, hold your hand over the vent where it exits your house. Is the air flow good or is it weak? Is the temperature warm or is it hot?
If you have weak air flow you have an obstruction, most likely in the blower housing. Check the "bird guard" on your vent outside to be sure it is free and clear. If you temperature is low you may have blown your hi-limit t-stat. You will need to replace it.
If you have no heat whatsoever, it may be the thermal fuse.
Posted on Feb 19, 2011
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
It is taking over 2 hours to dry a load of clothes. I stopped the cycle and opened the door to check the clothes. The dryer smelled like something was burning but no visible smoke. This is a fairly new...
Sounds like the vent is clogged with lint. You should have the vent cleaned once a year to keep the appliance operating properly. Also, make sure there are no kinks in the vent line.
liberty
Jan 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The clothes take forever to dry. Even with the more Dry cycle the clothes are wet after 40+ minutes The timing changes from 40 minutes then to one hour+.....
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Nov 23, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Takes three cycles to dry towels; i checked the venting but it goes up to roof so how do know if its blocked further up? My house is 5yrs old
usually long dry times is a restricted vent.. most vent are a straight shot out the back with longer vents excess buildup is common... unplug the vent in the back to the dryer and run a load if it heats quicker then u know ur venting is clogged up... hope this helps
Jan 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
DUET DRYER SEEMS TO BE STUCK ON MEDIUM TEMP. CLOTHES TAKE TOO LONG TO DRY
Hhi, Have you checked the vent that goes outside to see if it is plugging up? Make sure it is not pinched/kinked as well.
Is this gas or electric?
Vic
May 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet electric dryer taking too long to dry
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet 6.7 cu. ft. Electric Dryer Logo
145 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
