Question about Linksys Wireless-G WRT54G Router
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
We have configured linksys WRT54G Router at our home and two laptops(XP and Vista) are connecting fine with the router but the moment i try to connect lennovo 3000(Y500) which is having Intel PRO/Wireless 3945ABG Network Driver(bought 15 days back) it connects fine for the first time but after a minute or so the router power start fluctuating continuosly. Again when I disable the wireless network in lennovo 3000(Y500), power of router get stabilized on its own. So the problem is whenever i try to connect the lennovo machine having Intel PRO/Wireless 3945ABG Network Driver fluctuation of router starts and when i disable wireless connection, router works fine. I went through some forums and changed the power management properties in Intel PRO/Wireless 3945ABG Network Driver to the highest but it did not help me. Please help me regarding this. If possible please tell me do i need to upgrade the firmware of router, if it is so tell me how to do it. Thanks in advance.
  • sumit dayal May 17, 2007
    Thanks for the reply sandrew but this is not the case, I mean I have not connected wired and wireless at the same time.
    I just enabled the wireless network of the lenovo machine and router's intermittent behaviour starts though it was working fine on other laptops before enabling lenovo's wireless connection.
    Now, about the signal part other laptops are working fine even in the distance of 10-15 ft but lenovo is not working even in one or two ft distance.
    Regarding your last point, it is set on automatic obtain of ip address only.
    Thanks for your concern but it did not solve my problem.
    President:
  • 2,961 Answers
From what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
Posted on May 17, 2007
  • andrew pester
    andrew pester May 17, 2007
    just another thing to check is that maybe your router is set at 54MBPS transfer rate and the pc is set at a faster transfer rate e.g 108MBPS or 125MBPS, also check that the network card is set at the correct A, B or G configuration as your router will be set at 'G'
Need driver for 802.11g WLAN - Intel 3945 ABG for Vista Home. Can anyone send me link please?
Hi
Please click the mention below link and download the Driver for Intel 3945ABG
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+WiFi+Products&ProductProduct=Intel%C2%AE+PRO%2fWireless+3945ABG+Network+Connection
May 13, 2011 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Hi i am trying to access my home wireless network using my laptop. I get authentication error. I can connect to my home network by it says it is Unidentified Network for one and then it does not connect to...
you will be havin a wep or wpa security for wireless connection..type in that correctly..if u had forgotten it then connect ur laptop hardwire to ur router and configure router setting...type in 192.168.1.1 in ur browser address bar..ur router page will open..generally, by default password for router page will be "admin" or "password".. username will be "admin"...if u hav any issues then get back to me..
Jun 11, 2010 | Intel PRO/Wireless 3945ABG Network...
Dell Inspiron E1505- Intel(R) PROSet/Wireless 3945BG Network. I also have Comcast Cisco modem and cisco Linksys router. I was getting an error "problem applying profile". I went to the contorl...
I had usualy solved mysterious problems with other intel PRO wireless cards not authenticating, loosing signal, etc, by simply upgrading to the latest intel drivers.
Also using the Intel connection manager instead of the windows or Dell/other notebook manfucaturer's product is far more reliable.
Hope this helps.
Feb 09, 2010 | Intel PRO/Wireless 3945ABG Network...
Intel ProSet Wifi software can't connect to network
You need to manually add the network using your intel pro set utility. Or just switch to wzc.(wireless zero configuration). How to do it? just click start - go to run - type in services.msc - then look for wireless zero configuration on the list - right click on it then click start.
Then look for the wireless network connection icon on the system tray (that's in the bottom right hand corner of your screen). right click on it then select view available wireless network.
note: if you'll be getting the message "windows could not configure..." click change the order of preferred networks(that's in the same window where you're getting that message) then check the box that says "use windows to configure my wireless network settings" then click ok. after that go back to view available wireless networks then you should see your network now.
note: if you're using a corporate laptop where you don't have admin rights on it you need to use the intel pro
Dec 28, 2009 | Linksys Wireless-G WRT54G Router
Vista Wireless Problem: Intel Pro/Wireless 3945ABG
Hi Pete,
You sound like you know what you're doing, so forgive me if these suggestions seem foolish or patronising..
Does your laptop have a wireless button?
When you go to Internet Options and click the Connections tab, have you checked 'Never Dial a Connection'? This is essential..
I have exactly the same ethernet card and network adaptor, but haven't had any problems, and we have 2 laptops and 2 pc's here all detecting our router okay so..
It's definitely not MAC filtering on the router, as you would still see the network in your list..
I can only suggest uninstalling the Intel Pro Wireless driver and downloading a fresh one from here.
That'll reset default settings at least..
Hope this helps
Let me know how you get on.. If I face this problem I want to know how to fix it too!
Chris (ziraffa)
Dec 27, 2008 | Intel PRO/Wireless 3945ABG Network...
Intel PRO/Wireless 3945ABG Network Connection code 10
Code 10 usually means the device driver is not compatible, outdated or corrupt.
Try uninstalling the wireless device again and then reinstall using the latest driver available from:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2259&OSFullName=Windows+Vista*+Home+Premium%2C+32-bit+version&lang=eng&strOSs=153&submit=Go!
NB If you're running XP, use the second one.
Hope this helps
Chris (ziraffa)
Dec 08, 2008 | Intel PRO/Wireless 3945ABG Network...
Intel Pro Wireless 3945abg not connecting to higher speed DSL
router wireless limitations. if it was N type router it would go faster.
Oct 14, 2008 | Intel PRO/Wireless 3945ABG Network...
Intel Pro Wireless 2200BG problem or Linksys BEFW11S4 problem?
I had the same problem. If you are using the latest driver for your intel 2200BG (9.0.4.7). Try to roll back to a previous version. It solved my problems with being unable to connect to a Linksys BEFW11 router running WEP64.
I am now running driver version 9.0.1.9
Oct 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Linksys Wireless-G WRT54G Router Logo
2,094 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
