Question about Viper 7752V
Viper 7752v frozen
Today the truck started without me starting it, the remote is locked up frozen, none of the buttons will do anything and the time is stuck at 452 pm and hasnt changed
  • 35 Answers
If the battery is dead there is a guy on ebay that replaces them. He fixed my remote.
Posted on Feb 09, 2013
  • Brock Bascue
    Brock Bascue Mar 19, 2014
    There is also a website Viperremotebattery.com to buy the batteries
  • Brock Mar 28, 2014
    youtube video how to change it. http://www.youtube.com/watch?v=GGnG5iCX0...
3 Suggested Answers
  • 22 Answers
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Posted on Dec 04, 2008
SOURCE: viper remote starter-
Have this problem also. Took new vehicle (5009.2 miles) to dealer. They suggest that something in the control module tends to stick causing the battery to drain and that it is not an uncommon problem that they see. We had single digit temperatures here when the problem occured. It got up to 20 yesterday and everything works well again.
Posted on Jan 04, 2010
My sst 7752v viper remote will not unlock my doors, it just beeps. I cant get into my truck without my remote... please help
how old is the remote is a question to consider. the batteries might just be too low to send a strong enough signal for the truck's transponder to receive. does the remote need to be coded to the truck if not more than likely its weak batteries. the LCD display doesn't need much power to light up, but the remote does to send the signal.
Aug 08, 2013 | 7752V Replacement Transmitter Supercode...
I need a charger for 7752v remote
you can charge it from your computer if you have a mini usb cable like one from a camera would work. Also if you have an old cell phone charger that has the mini usb connector on the end will work. The motorola driod x charger would be a perfect match. If you need to replace the battery because the remote will not turn on any more I replace the batteries on ebay search viper 7752 remote battery service. Hopefully this helps.
Feb 05, 2013 | Viper Televison & Video
Remote 7752v dead wont start
I replace the batteries in the remotes search ebay viper 7752 remote battery replacement.
Dec 02, 2012 | Viper 7752V
How to set viper 7752v remote on vibrate
Press and hold the "f" button the remote for approx. 8 seconds. The screen will display remote setup. Press the Aux button to scroll up and the remote starter button to scroll down. Press and hold the "f" button to enter the selected feature, which would be page alert. When the option you want is displayed on the LCD screen (vibe,tone,both,off) press and hold the "f' to save. You can press lock or unlock at anytime to exit the remote programming.
You can also press "f" then lock or unlock to silent arm or disarm without going through the above programming procedure.
Aug 20, 2012 | 7752V Replacement Transmitter Supercode...
Need viper 7752v owners manual
The 7752V remote is compatible with five Viper systems. The owners manuals for each respective system can be downloaded via the following links:
5904
4704
5501
5901
5704
Nov 15, 2011 | Remote Start System
I just received a brand new viper 7752v remote and it will not power on even when plugged into the charger. I have tried to press the function key several times to reset it and nothing. Any Suggestions?
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
Jul 11, 2011 | 7752V Replacement Transmitter Supercode...
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Feb 08, 2011 | 7752V Replacement Transmitter Supercode...
Just baught a truck with a viper alarm, worked great then today i unlocked the truck with the viper remote and when i open the door the horn goes crazy for for about 1 min not the accual alarm! but at the...
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at jared@underground-audio.net if you'd like.
Nov 17, 2010 | 7752V Replacement Transmitter Supercode...
Viper 7752V Logo
299 people viewed this question
Top Viper Televison & Video Experts
Paul Bade
richie46
Gil Shultz
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
