Question about Kicker Car Audio & Video
Kicker l7 crackling noise in low volume
Crackling noise only when in low volume. when volume turned up still hear it but not too much
  • 14 Answers
SOURCE: Kicker L7 Repair
With the price of speakers dropping all the time it's really not worth repairing as it will cost too much to have it fixed by hand.
Posted on Dec 28, 2007
  • 173 Answers
SOURCE: kicker L7
like a poping noise is due to to high of a frequency in a sealed box try a ported box for beter sound. if it is wratiling noise u can use a screwdriver to push in the screen on the very botom were the magnet is and shake the speaker if u see small pices of black and yellow stuff fall out your about to blow it completly thats from stress usualy from the gain to hi or a cross over set at 12+ db i would recamend u try to shake the speaker and see if it s wrataling due to it braking
Posted on Sep 14, 2008
duby1990
  • 367 Answers
SOURCE: wiring my 2 L7 with a kicker 1000times1
Run the subs in series then bridge the amp. So run the normal + to - to the one sub then hook up a spare wire (not connected to the amp) to the same + and - connections. Then run the spare wire to the + and - of the other sub. This will tie the 2 together so you can bridge the ampfor more power instead of using 2 seperate channels.
Posted on Feb 06, 2009
  • 18 Answers
SOURCE: My kicker 10'' L7
Check wires that go into the speaker.Try turning the bass down than turn the volume up.If it sounds good when volumes down and as you turn it up it gets worse your amp isnt putting out enough power.whats the amp? power wire gauge should be same as ground.what gauge are they? Check ground to make shure you are getting a good connection & power wire isn't loose at any of the connection what size fuse are you running under the hood?
Posted on Mar 03, 2009
etirbynnor
  • 655 Answers
SOURCE: What Amp would i need to push three Kicker L7 12's?
It depends on the specific subs and exactly what you want out of them. You have practically unlimited choices for amps.
The 10" L7 has a power range of from 30-600 watts RMS, the 12" from 50-750 watts, and the 15" from 100-1000 watts.
So if you have the 10's, you would want an amp that puts out at least 90 watts RMS and not more that 1,800. Unless you are really into SPL and have an unlimited budget, it's probably best to go somewhere in between.
Keep in mind that these Kickers need to be in a proper enclosure. They like a little more volume to work as compared to RF's or MTX's and some others.
Posted on Mar 30, 2009
I have a kicker ix 500.4 hookd up to polk audio 6x9 and 6.5. if you play the system past about 25 volume the subs will keep playing but the speakers will cut out for a few seconds as if its hiting the
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
I have a 2008 kicker l7 15 and it hits fine when the volume is mid range but if i go up on the volume it makes this poping sound the amp is tune down
You need to turn DOWN your LPF....(low pass filter). You are driving the sub with a higher Hz than it is rated for. If your amp (or head unit) doesn't have a good LPF, then you are going to do damage to the sub over time.
Please rate if this helped!
Apr 06, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I hear distortion in my L7 Kicker when the truck is on, but when I turn the engine off it sounds fine. It sounds like its coming from the engine.
Your amp is picking up engine noise. There are couple of things you can do:
1. Can shorten the ground wire and find a better chassis ground.
2. Find inline noise suppressor and install it.
Sep 21, 2010 | Car Audio & Video
No bass
if it is under 1 year old kicker will replace it free of charge if you have proof of purchase
Dec 25, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a brand new L7 is it blown?
check to make sure your box is securely sealed and that the box itself is not rattling. if not, most subs require a break in period where they can not be played full gain/full volume for the first 48 or so hours... did you break in your subs by paying it softly the first day and slowly turning your amps gain and receivers volume up the next couple of days. if not, it is likely blown
Oct 07, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
When i plug it in all i hear is a rattle buzz noise. Is there a kicker place that I can send it in for repairs? if so, where?
more likely speaker is blown .go to kicker website and check for your nearest service center.Most cases its not worth shipping ,repair cost for this .
Jul 30, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker CVR 10" "stuck"
sounds like the wiring in the speaker from the factory is shoty. rare but does happen. if you bought this from a retailer and have all of your warranty information id send it back and let em fix it
Mar 03, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My kicker 10'' L7 sub works when the volume is low, when the volume is turned up the sub. stops working. Why?
Mar 01, 2009 | Car Audio & Video
Problem with amp?
Give that new sub a chance to "break in". New speakers require a few hours of use before the voice coil(s) and spider break in and began operating at their best performance. Is the box within the operating specs of the sub? Is this a ported box; if so you will here some turbulance type noise from the port. What type of distortion are you hearing? Alternator noise(dentist drill like sound) would only be noticable through a sub at lower volumes due to the frequency response of a sub. Is the amps lowpass crossover turned on?
Mar 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Kicker L7 Repair
Dec 26, 2007 | Q-Logic QLT-.3508SS Car Subwoofer
Car Audio & Video Logo
46 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
