Question about Cisco Linksys SPA2102 Phone Adapter with Router
My phone is not working
I cannot make calls
  • 580 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Nov 01, 2012
Samsung Gt-s5233w turns on does every thing except calling or taking calls or SMS or making calls it has a MSG on screen says Emergency calls only ho do I make my phone work I'm with optus
menu, settings and tools, call settings, location....that might work. Id on't have that exact phone so it may be a little different on your phone.
Sep 16, 2012 | Samsung Star GT-S5233 Cell Phone
Why not display incoming calls
Is your display on your phone working, and its just that the incoming calls notification is not working when you recieve calls? Have you tried a hard reset? (battery pull)
If your phones display is functioning, then more then likely it has to do with your settings of your phone. A long time ago with a older phone I had, I accidentally some how turned off my phones incoming calls notification. I was able to remedy this, but calling the phone company and they walked me through how to go into my phones settings and turn the incoming calls notifications back on. I would try this if you cant find it under your phones settings to turn the incoming calls notifications back on. Hope this helps. ;)
Mar 08, 2012 | Cell Phones
I can't get the internal phone calls to ring at my phone
I can think of about 4 reasons why it won't work. What have you done so far?
The AUTO ANS switch could be set on, which would make the calls be Voice Announce.
The ringer could be turned off.
Your call forward or DND button could be on, making the calls go to another location.
The port could be bad.
Start by calling another display phone so you know your extension. Then have somebody call you and look at their display. If the call is being forwarded, the display will tell you. Also, on your phone, listen to the dial tone, if it stutters, then you have a feature set. Dial 790# to reset it and try have someone call you again.
Swap phones. If another phone works in your location, it's a bad phone.
At some point in time, one thing or another will work, or you're down to a bad port in the phone system.
Carl
Jan 21, 2011 | Panasonic KX T7235 Corded Phone
Does just one handset works for call or are they suppose to work both hat the same time?
DECT cordless phones associated with the same base unit will all ring when an incoming call is recived, however only one handset can answer the call.
Unlike a corded phone, another handset cannot "join" an ongoing call, but the call can be transfered between handsets - your phone's manual will tell you how.
Nov 04, 2009 | Uniden Cordless Phone
Call Forward not working
Sounds like an IPK2. try just entering the forward destination in the first 2 fields. Why would the person being forwarded need calls? If you are forwarding his phone he can't receive calls. unless your just forwarding to vmail. cheaper rates at ldtsnj.com
Mar 19, 2009 | NEC Electra Elite 32D-1 Corded Phone
Cant Call out. No calls in Samsung P520 Georgio Armani
hi im josh in cebu phils. may i help you? if it happened the call or your call is diverted to restricted area. you can go to phone settings then call setting then change the diverted or disable it. re direct the call on. or try to reset defaults to solve the problem. no problem in your phone it is in your setting so try to work for it. good luck hope i helped you.
Feb 26, 2009 | Samsung: P520 Giorgio Armani Edition Cell...
Other two phones do not work
This feature that you are experiencing is called exclusion. When you answer a call on one phone you cannot listen to the call on the other phones. Keeps ease droppers from listening. If you have the manual to the phone there will be a feature in there that will tell you how to turn it on and off
Dec 28, 2008 | Uniden Cordless Phone
My phone does not ring when a call is received
I've found this to be a problem with regular phone lines (POTS) and Uniden phones. Uniden phones do not seem to support 90v @ 20hz ringing voltage / frequency. They work fine in every aspect except for ringing. These phones do work well with voip, where you aren't connected to the telephone company and have calls routed over the internet. The boxes that handle the voip calls generally produce less than 90v and work well w/ Uniden phones.
Dec 18, 2008 | Uniden TRU8885 Digital Answering Machine
Problem with Calls
if the phone is still under warranty go get a new one otherwise it sounds like a serious hardware problem!!!!
Feb 28, 2007 | Motorola Mobility RAZR V3
Cisco Linksys SPA2102 Phone Adapter with Router Logo
100 people viewed this question
Top Cisco Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Cisco Lands Phone Expert? Answer questions, earn points and help others
