Question about Panasonic PT-52LCX35
I cant get the cc to come ON and ive tried all combinations with the modes, primary and Analog settings can u tell me what to put them on to get my CC to come ON
I dont hv a remote but i do know how to manuevar through the buttons for the menu items
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Two ways to get CC, if using a cable or sat box it should have this feature----in the menu for the TV there should be a item for captions---once you select it try CC1 which is the most common one of cc1-cc4-----if on the wrong one no cc.
If you find that menu and get it working many sets there have a setting so the captions will only appear if the sound is muted and not all the time----look for that one also.
Posted on Nov 01, 2012
Ok i posted a question in regard to a black box appearing on my screen. Ive been through the subtitle section its off i cant for the life of me find the section for cc. I looked in menu but no luck
Closed captioning (CC) usually is enabled/disabled as part of the initial set up routine. Once enabled, CC text is displayed whenever normal TV audio is turned off, e.g., by pressing the MUTE button on the remote.
Apr 05, 2016 | Televison & Video
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
How can I remove the closed captioning from my TV
You can set the CC on or off from the MENU - SETUP (use your remote, after you turn on the TV )
Then select Closed Caption (using your up / down arrow)
And then select Digital / Analog CC mode ... press OK
Then, (using the left / right arrow button) set it to OFF
Mar 03, 2014 | Element Electronics FLX3210 32 in. LCD TV
Hi, I sent an earlier e-mail. Not sure it got through so repeating. Thanks. I am hearing impaired. My cat stepped on the remote and for some reason I can't get the closed captioning to work. Do you...
I would be surprised if the cat stepping on the remote control had anything to do with your problem unless the cat somehow managed to turn on "CC when mute" with the right combination of buttons (more on this below).
This procedure for setting closed caption is from the owner's manual. (p. xx is the Adobe Reader page # for the PDF version of the manual.) CC is not available for the YPbPr, VGA or DVI inputs:
  1. With the set on, press the Menu button. (p. 20)
  2. Use Ch +/- to select the Setup item. Press <Enter> to go into Setup. (p. 20)
  3. Use Ch +/- to select CC On/Off. The current status of CC should be displayed at the bottom of the CC setup window. If it is off, press <Enter> to turn it on. (p. 36, p. 20)
  4. Use Ch +/- to go to the CC Mode. The current mode should be displayed at the bottom of the CC setup window. Use Vol +/- to step through the modes. When you have the one you want, press <Enter> to confirm the selection. (p. 36, p. 20)
  5. When you have the settings you want, press Menu again to escape the sub-menu.
Note: the "CC when mute" turns on CC only when Mute is on. Check this CC menu item to see if it is on. It may override the CC On/Off if it was chosen after CC was turned on.
One last VERY IMPORTANT ITEM: The U. S. Consumer Product Safety Commission and Best Buy announced a recall on the IS-LCDTV26 models sold by Best Buy. Apparently there is a risk the power supply can overheat to the point of being a fire and burn hazard. The announcement, dated April 2, 2009, says to return the set to Best Buy to get a gift card for the value of a replacement TV. I don't know if the recall affects sets sold by other retailers. If this set is under recall, it is illegal to resell it. It is possible that you have a different version of the power supply and that's why you haven't had any problems so far, but you should check this out.
Jan 29, 2011 | Insignia LCDTV26 26 in. Television
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
JVC model LT42EM59 closed captioning now gone
checked with satellite company and they have admited this is an intermittant problem with them and they will be creating software to download to correct
Jan 04, 2009 | JVC AV-32120 32" TV
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Missing Close Captioning in analog Sony Trinitron
Make sure the CC is not just turned on but in the menu make sure it is set to caption 1.
Jun 20, 2008 | Hitachi 42HDT79 42 in. Plasma Television
Panasonic PT-52LCX35 Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
