I need a ac adapter for my concertmate 1000!!!
Concertmate 1000 keyboard AC adapter AC120v 7.7w
tom19511
  • 1601 Answers
SOURCE: Compaq Presario 2100, remove keyboard
Here you go
All you need is here.
http://h10032.www1.hp.com/ctg/Manual/c00246219.pdf
Posted on Oct 23, 2007
Benimur
  • 6966 Answers
SOURCE: Need to replace DVE AC Adapter
If your desk charger is the version that can accommodate 2 units for simultaneous charging, any wall adapter would do as long as it is rated at 9VAC @ 450mA or higher. Since most wall adapters are DC output, you need to open it and remove the diode(s) and capacitor and connect the output of the secondary straight to the wires. Additionally, you need to get one whose plug will match the jack of the desk charger.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 23, 2008
greenspan
  • 1734 Answers
SOURCE: Manual Concertmate 990
There are Concertmate manuals here:
http://music.manualsonline.com/ex/thread/view/idThread/2501867
Posted on Nov 11, 2009
SOURCE: Shark cordless 15,6v need to buy ac adapter Ktec KA12D220020034U
need a Ktec ac adapter listed above. KA12D220020034U. HOW MUCH FOR THE ADAPTOR AND HOW SOON CAN I GET IT.
Posted on Mar 25, 2010
kc5uzd
  • 13 Answers
SOURCE: need ac adapter for speakers
If you're in the US, go to Radio Shack and buy a plug in transformer that puts out 12VDC at 1000mA.
The polarity is negative (-) on the outside and positive (+) on the inside.
Posted on Apr 28, 2010
Replacing ac power adapter.
If the polarity, voltage, and amperage are the same, there is no reason that you cannot use this device as an alternate.
Oct 16, 2016 | Roland Music
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Keyboard AC Adapter
If thje voltage is the same, the current rating is fine at 1000-1400 mA. The accessory will use the amount of current it needs and the fact that there is more "available" does not mean it will use it. The higher current rating will not ruin the equipment. Just make sure the voltage rating is the same. Cheers!
Mar 09, 2014 | Casio AD5 Keyboard AC Adapter
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Have keyboard concertmate 1100 but need the adapter to plug in - can these be found and bought?
Should look to buy a new adapter, or another old one around the house with the same specifications. I'm actually using an Ibanez wireless instrument pack adapter. Just make sure it's a DC 9V 200mA adapter, and you should be good to go!
Apr 30, 2011 | Audio Players & Recorders
My hp mini 1000 will not turn on. When I plug it in the light on the side will not say it is charging. It will not charge.
Here are some steps that can help you resolve the issue.
First, try removing the ac adapater and the battery and press and hold the power button for about 10-15 secs to remove the flea power. Then try to deattached the power cable and the power brick and attach it again properly, plug it to the computer without the battery and try to turn on the computer. If still the same problem try a good known power socket, if your using power strip try to plug it directly to the wall socket. If nothing works, try a good known ac adapter, or try you ac adapter to a good known working computer. If a good known ac adapter didnt work, contact HP as this is a power supply issue on the computer (power supply are mostly attached to motherboard for portables) contact HP to check your warranty and have it serviced. If the good known ac adapter works, contact HP to check the warranty and have the AC adapater replace or simply replace the ac adapter.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 10, 2011 | HP Mini 1000 Netbook
What could be the problem if the power does not come on?
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
Jan 23, 2011 | Nintendo Wii Console
I need parts for a Yamaha PSR 1000....Help
Not sure exactly what parts are you after, but you can find AC Adapter and lowering links on Ebay. You can also find parts at music stores.
Nov 29, 2010 | Yamaha Full-Size Keyboard
MX1000
wanda
Strange, I just left logitech page for MX 1000 Laser Cordless Mouse. All they sell is the AC Adapter. Thought that was odd.
Their not selling replacement batterys, just the AC adapter.
Click this link: http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryID.11197300
If you scroll down to the bottom of the page & look to the right there is a toll free No# you can call.
Still find it strange that logitech sells the AC adapter & not the battery. Make you think your battery is good & the adapter is bad.
Good Luck & kind Regards.
& please vote.
Feb 24, 2008 | Logitech Cordless Mouse
177 people viewed this question
 Grubhead
Grubhead
